Old school MM issue
fastbaja5b
fastbaja5b's Avatar
Old school MM issue - 06.30.2011, 10:12 AM
Dug out an old MM I had which I'd never looked at since it stopped working one day.
Updated firmware to 1.30
Unit powers up fine but won't power the receiver, when an external battery pack is fitted to rec, all 3 LED's flash and no response to throttle input
Repairable? Needs a new case (or A CASE!) or can I upgrade this thing?
Say Less, Do More.
brushlessboy16
brushlessboy16's Avatar
06.30.2011, 10:13 AM
when your using the external battery pack, do you pull the red wire from the MM receiver wire?
fastbaja5b
fastbaja5b's Avatar
06.30.2011, 10:31 AM
tried with and without, no change
Say Less, Do More.
bdebde
That's All Folks!
bdebde's Avatar
06.30.2011, 07:27 PM
1.30 won't work on some MM's (none of mine), try 1.23
