need help choseing a brushless motor
2 FAST 4 U
NOS Throttle in a Bottle
2 FAST 4 U's Avatar
need help choseing a brushless motor - 07.01.2006, 02:54 AM
I have A Brushless E-maxx that weighs 12&1/2 pounds haven"t driven it much as I only get about 4 minutes run time with The Novak HV-Maxx Brushless System any suggestions as to what brushless moter and speed control I can get to give me 20 min run time or more and 40mph or more thinking about getting lithium batteries http://www2.towerhobbies.com/cgi-bin...?&I=LXKLK8&P=0
It's not a monster truck til it has a big block
coolhandcountry
coolhandcountry's Avatar
07.01.2006, 07:08 AM
6400 mah 14.8 volt 20 mins is pretty easy. 8xl should get you there.
Peace!
Country
Help support the
Rc-Monster
Buy here
Sylvester
Sylvester's Avatar
07.01.2006, 09:42 AM
or a lehner 1950 could be even better!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
neweuser
neweuser's Avatar
07.01.2006, 09:59 AM
Run time not only includes an efficient motor, but good batts too. 5min hv maxx? what are you running for batts and gearing? I used to be able to almost hit the 25 min mark....
2 FAST 4 U
2 FAST 4 U's Avatar
07.01.2006, 08:10 PM
if I used the Lehner(LMT) 1950 motor what motor wind would be good And what would be a good speed control for it that can handle litium batteries?and what are the most powerful litium batteries out there? about what run time and speed would I get?thinking about converting it to single speed trans. Thanks
http://www.rc-monster.com/proddetail...MM160243sHCS01
coolhandcountry
07.01.2006, 08:16 PM
1950 7t quark 125b with 4s lipo in the 6400 mah would be a great set up.
Peace!
Country
Help support the
Rc-Monster
Buy here
captain harlock
RC-Monster Captain
captain harlock's Avatar
07.01.2006, 08:19 PM
Use a small pinion if you can to get more runtimes.
Nice to meet you!
2 FAST 4 U
2 FAST 4 U's Avatar
07.02.2006, 12:42 AM
about what speed and run time would I get with the Lehner(LMT) 1950 motor
and http://www.maxamps.com/contents/en-u...d=38889.712500
would it be possible to got almost an hour run time? and still do 40 mph , the gearing I have right now is a 72 spur gear with 14 tooth pinion, and battery I"ve been useing 3000 vinum raceing Thanks
dda01015
07.02.2006, 02:00 AM
Looks like there are 'High Amp' versions of some of the Lehner 1950's. What's that about?
coolhandcountry
07.02.2006, 07:47 AM
If you go with the 12000 mah packs. You should get up in the region of an hour. You could drop back to a 1950 9t 8000mah 3s2p have more power with great run time as well.
Peace!
Country
Help support the
Rc-Monster
Buy here
2 FAST 4 U
2 FAST 4 U's Avatar
07.02.2006, 08:06 PM
where can I find the 8000mah 3s2p ? would I use 1or2 battery pack About how much run time and top speed would I get? with the 1950 9t
Thanks
coolhandcountry
07.02.2006, 09:23 PM
you would use 2 8000 mah 3s 2p packs. You should see 40 mph pretty easy and should get close to an hour of run.
Peace!
Country
Help support the
Rc-Monster
Buy here
squeeforever
squeeforever's Avatar
07.02.2006, 11:16 PM
On a 8T, I think you would get around 58mph so a 9T i would say around 53ish at an hour+ runtime easy.
2 FAST 4 U
2 FAST 4 U's Avatar
07.03.2006, 12:23 AM
MaxAmps Lipoly 8000mah 3S2P 11.1V Pack are these the batteries you were talking about ? Do I run both batteries on same speed control? Should I convert to single or 2 speed trans? What gearing would be good? I"am going to build a new trans with http://www.rc-monster.com/proddetail...xtranny&cat=47 http://www.rc-monster.com/proddetail...RO_DIFF&cat=47
http://www.rc-monster.com/proddetail...03idler&cat=47
was wondering if I should use stock slipper clutch? Thanks to all for your helpful imput.
HotnCold
HotnCold's Avatar
07.03.2006, 07:10 AM
Strobe slipper would be better. But if you decide to go with the stocker - crank her down - with big power it wont be long before she melts like a ice cream cone on a 100 degree day. Kinda defeats the point of having a slipper if you have to crank it down all the way though. But she will melt fast if you dont....( dont ask me how i know :027: )
Hows that "Hope and Change" working out for Ya???
