my try of a watercooled savage
rhylsadar
rhylsadar's Avatar
my try of a watercooled savage - 01.25.2007, 03:59 PM
hi
here is my savage that i modded to a watercooled system.
components: bk 20120 wk, wanderer 9XL, 20cells, gearing 20/52 (fixed in first gear). a rc colleage of mine has modded his schulze 18.97kw (pics below) to used it with watercooling for his bl mp 7.5.
in my frist try i used a nitropump from sullivan that works from 6v - 12v. the powersource was a 2s liion battery pack. i tried the setup since september 06. so the hardcore test in summer is still missing. but with outside temps around 20° i didn't need the pumps so i took it away. now i only have this small "handpump" that i push a few times when changing batteries.
the radiator is made out of two small copper parts with two copper heatsinks that are used for the ram blocks in pc's. some little antioxidant in the water.
the equalisation tank is also from sullivan. its a 1oz small flextank (you can heat it up and form it).
experience so far after about 25 runs. the controller is the coolest part and never got over 60° even after two 20cell-runs. so i had no temp issues so far. the motor got quite hot (70°). i have to say it wasn't on a track but bashing in the gravel pit. at a track with nonstop power it may be different.
the truck is quite heavy (around 8kg). of course i made the "usual" strengthening mods (alu diff cups with slide blocks, trimmed cups for two extra outerbearings in the alu bulks, big center cups and shafts, 4 pin mod on the gearshaft etc). i also fabricated a nylon rollbar out of an FG roll bar.
the truck holds up pretty good till now. the next step is to include the motor in the water circuit. i couldn't do it yet because i have gotten the wrong mantle from bk. 6S lipos would may bring the weight somewhat down. maybe i will switch the motor to a 1950 lehner.
bye
rhylsadar
the controller
the radiator
front
rear
side
downside
the 4 pin gear shaft
trimmed diff cups
trimmed 43t (left) to use a 8x16 instead of 10x16 bearing
diff
trimmed bulk (shown on the plastic)
the pump
center shafts
fat cup
the watercooled schulze controller
______________________
Exercitatio artem paravit
rhylsadar at youtube
