crt .5 plastic spur thoughts
entjoles
crt .5 plastic spur thoughts - 10.21.2007, 09:53 AM
i was looking at the robinson racing spur and thinking
http://www3.towerhobbies.com/cgi-bin...&I=LXSNC8&P=SM
could i mount this up and modify a plastic spur to bolt up to this by cutting out the center of it and bolting it together?
http://www3.towerhobbies.com/cgi-bin...&I=LXGFW9&P=SM
it looks possible, i would just need to have clearance on the sevo and run the pinion out a little bit
let me know your thoughts on this thanks
Serum
Serum's Avatar
10.21.2007, 11:44 AM
You don't necessarily need a plastic spur. You could use a hardened pinion.
jhautz
jhautz's Avatar
10.21.2007, 12:50 PM
Serum is right. Save yourself the trouble and just run the stock steel spur with one of Mikes hardened pinions. They work great.
to make it...
or break it...
Silent...But Deadly
entjoles
10.21.2007, 05:23 PM
thanks, i am running those pinions now, i was just trying to make it more quite
10.21.2007, 07:42 PM
One word: earplugs.
Seriously, if you are really concerned about it, you could use a Kyosho 46T spur, but will need other modifications. You could even use a CD from a 8th scale buggy if you are going to go that far. But, the footprint will be different, which will require new chassis holes and shorter driveshaft.
I did quite a bit of discussion about using different spurs in this thread (starts at post #117). There are a bunch of pics and measurements of the spurs and different ideas I had if that helps you at all...
entjoles
10.21.2007, 09:26 PM
thanks for the link,
i will be reading for awhile, i must have read this before and forgot about it, i never have original ideas
