How's the Vista?
BitHed
How's the Vista? - 09.27.2007, 12:14 PM
...ok :( Sucked in and spat out the other end...So HOW, without the use of a screwdriver and / or duct tape, do i get Castle Link into my sparkly new VISTA pc? Hmm?
MetalMan
MetalMan's Avatar
09.27.2007, 01:51 PM
When I installed it onto my "sparkling new" laptop, I had to right-click on the downloaded setup file, and choose "Properties." Then select the tab labelled "Compatibility," then check the box at the bottom next to "Run this program as an administrator." Click "OK," then run the setup file again (should be V3.01, BTW). Once it's installed it should work just fine :).
09.27.2007, 05:49 PM
UNLESS... you run vista 64 (like moi) in which case get your xp cd out!
bluonyx
09.27.2007, 08:16 PM
It wouldn't work with my Vista till I installed it with the Compatibility Mode box checked. Run the setup.exe under Windows XP (Service Pack 2) and you shouldn't have any problems. Once it installed I right clicked the Castelink shortcut and under properties made sure again that the compatibility box was checked in Windows XP mode.
BitHed
09.27.2007, 11:31 PM
...Thanks fellas..I will give all of that a shot...
Success!!
BitHed
Success!! - 09.28.2007, 10:06 PM
...Well done boys!!! its all good...just for the record...
...Right-click on the downloaded V3.01 setup file, and choose "Properties."
...Select the tab labelled "Compatibility,"
...Check the box at the bottom next to "Run this program as an administrator."
...Click "OK," then run the setup file again...
...This is essentially what MetalMan advised and it worked fine...I would have got you a screen shot of this but mine is all in Japanese and probabably not very helpful ;)
Serum
Serum's Avatar
09.29.2007, 04:54 AM
Install XP..
that's what i did..
Vista is seriously lacking for me, i had numerous compatibility problems..
BitHed
10.01.2007, 04:19 AM
...Vista wont take Skype either :( Looks pretty though...
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
10.02.2007, 08:34 AM
You shouldn't have to run in compatibility mode gents. When you click on "download now" on our website, then click on "I have read and understand this information, download now" it asks if you want to save the install file or run it. Choose save, and save it to your desktop. After it's done, go to your desktop and right click on the installation file...choose "run as administrator" and it will install and function just fine. :)
Joe Ford
Product Specialist
10.03.2007, 02:00 PM
Joe - Have you done any testing on Vista 64 - it installs ok but you can't install a driver for the actual MM when you plug it in.
10.29.2007, 11:04 PM
Joe any update on vista64 support?
Joe Ford
Joe Ford's Avatar
10.31.2007, 04:32 PM
No...there are no compatible drivers at this time unfortunately. Drivers are hard to come by for 64 bit...for any software out there. :(
Joe Ford
Product Specialist
