best method to mix diff oil?
blueb8llz
best method to mix diff oil? - 07.16.2008, 06:03 PM
i couldnt find any 75k oil so i bought 100k and 50k. is the best way to squeeze both bottles into the diff at the same time the best way, or should i squeeze both oil into cup and mix cup then pour the oil into diff? anyone got better methods or is it a no no to mix the oil.
the brand is ofna.
BP-Revo
BMW M Power!
BP-Revo's Avatar
07.16.2008, 06:05 PM
Well, if you pour it into a bottle before pouring it into the diff, you will need to properly mix the bottle by stirring or a lot of shaking.
Otherwise, if you just pour about half and half straight into the diff, you wont need to mix it as the diff will mix it itself after a few seconds of running.
brushlessboy16
brushlessboy16's Avatar
07.16.2008, 06:36 PM
Bp got it. just throw em in ther then drive some circles and they will be mixed in no time
rchippie
rchippie's Avatar
07.16.2008, 07:03 PM
the brand is ofna.
Use this program.
http://scriptasylum.com/rc_speed/_oil_mixer.html
REAL MEN RUN BRUSHLESS
blueb8llz
07.16.2008, 08:29 PM
thats a great calculator...thanks for that link!
but if i mixed them two into the diff at same time, i was thinking maybe the the thicker oil will stay on top and wouldnt mix on its own, so thats why i wanted to know if i should mix it by myself in a bottle....so im wrong...just double checkin.
rchippie
rchippie's Avatar
07.16.2008, 08:32 PM
The way i do it is as follows . Take a empty oil bottle & mix them in there then pour it into your diff cup . Put the heavier oil in to the empty bottlr first . then put the thinner oil in. Then turn the bottle side to side to mix. I would'nt sake it because you will put a lot of air bubbles in the mix. But if you do shake it all you have to do is wait till the bubbled rise to the surface & escape.
George16
Supermaxx
George16's Avatar
07.16.2008, 09:33 PM
Use this calculator and then mix it well by stirring the mixture. You can put the oils one at a time. If you have a plastic syringe, use it to get the correct amount. I work in the hospital so I have a lot of them .
http://www.gesilicones.com/gesilwiza...ng/fluid2.html
After you get the correct consistency/viscosity, just pour them or use the syringe to put the oil into the diff cup.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.16.2008, 10:09 PM
That is the calculator I use and also do the syringe trick (my sister in law works in a hospital)
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
rchippie
rchippie's Avatar
07.16.2008, 10:31 PM
Brian's oil calculator is based of that oil calculator .
Finnster
KillaHurtz
Finnster's Avatar
07.16.2008, 10:34 PM
I use a syringe too (no hospital work for me tho ;) ) I usually make quite a bit and put into another bottle if I think I'm going to use more of it. The bottles ofna sells are huge.
jayjay283
jayjay283's Avatar
07.16.2008, 10:42 PM
Just dump the stuff in the diffs until you think its close, just try and make sure its a bit thicker in the front diff. You cant tell if its off by 10,000 weight in those slopppy emaxx diffs anyway. Just make sure not to WOT it right off until the stuff gets mixed up lol
George16
Supermaxx
George16's Avatar
07.17.2008, 12:47 AM
Jay, that's so funny .
Revo with OS .18TZ
blueb8llz
07.17.2008, 04:51 AM
ok diff all put back together..too late to run it now , but i took everyones advice and thanks all for the help.
