Dimension Engineering Sport BEC -
01.26.2009, 08:58 PM
Is anybody using this BEC with their Sidewinder or MM ESC? Did you have to cut the red wire from the ESC? I just installed this BEC on my sidewinder without removing/cutting the red wire. Is this good or bad.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
That BEC has a throttle cable pass-through, which just allows the negative and signal wires through. So, it automatically disconnects the red wire without having to mod the throttle cable.
Revo with OS .18TZ
For what it worth (right or wrong) I pulled my red wire on my MM.. But BrainG is the GOD of knowledge so I would go with what he said.. Maybe hahhahaaa..
I generally do the same (pull the red wire) in any BEC just to be consistent, but it's much easier to just use the pass-through feature. In the case of the SportBEC, you can actually follow the red wire PCB trace and you'll see it does not go anywehere on the BEC.
