Question about c-50
Sneeck
RC-Monster Custom
Sneeck's Avatar
Question about c-50 - 01.08.2006, 11:11 AM
I'm running a normal c-50 in my maxx, however i've just bought a special limited edition c-50, which look's awesome.
The only down side of the motor i'm buying, it's got a broken spool(pinion snapped off). Now my original plan was to use the spool of my current c-50. But since i've always been slightly consurnd about the weak 3,2 mm shaft, are there any other spool's that will fit the c-50 but with a 5mm shaft?
Also does anyone happen to know the kv rating of the c-50's?
Thank's.
  Send a message via MSN to Sneeck
coolhandcountry
coolhandcountry's Avatar
01.08.2006, 11:19 AM
The kv was around 3000. If you got the one for the maxx they have. May be able to put a feigao shaft or somethign in it.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.08.2006, 11:25 AM
Depends on the wind(Kv is determined by the windings, not the magnet). Pretty sure a Feigao or Hacker shaft would fit right in, but there are some issues to this theory. The best for that motor would be a Hacker rotor(make sure proper clearance from shaft to windings), with a 5mm shaft. I say use your current motor's shaft and keep the pinion closer to the motor can when you mount it to avoid the potential for a broken shaft(most times, the shaft is broken due to high stress when the pinion is mounted way out on the end of the shaft-leverage will win!).
Sneeck
RC-Monster Custom
Sneeck's Avatar
01.08.2006, 12:30 PM
In this case the previous owner had run his gmaxx with a tight slipper and hit a car tire at full throttle, while during the crash still giving throttle. Since the motor didn't had a chance to get the power away, the shaft broke.
http://i25.photobucket.com/albums/c8...r/125_2517.jpg
If you(Mike or anyone else) want's I can take measurement of the motor/ spool when I get it?
RC-Monster Mike
Site Owner
01.08.2006, 01:02 PM
Did the shaft break, or did the rotor dislocate from the shaft?
Sneeck
RC-Monster Custom
Sneeck's Avatar
01.08.2006, 01:09 PM
If you look closely it broke on the point where the shaft was getting thinner.
Superemaxx89
01.08.2006, 10:29 PM
the flat area?
Sneeck
RC-Monster Custom
Sneeck's Avatar
01.09.2006, 01:51 AM
Yep.
Promod
01.10.2006, 02:12 PM
I have two of the C50 maxx motors. Ran them as a dual set-up until the one motor broke the shaft. Than ran the other motor as a single. It lasted about three packs before that motors shaft broke.
The shaft on these motors must be WEAK as there were a good number of people who broke shafts on these motors. A 5mm shaft would be a wise choice.
Thank you,
Promod
Sneeck
RC-Monster Custom
Sneeck's Avatar
01.10.2006, 02:28 PM
Actually(and I have to knock on a piece of wood really hard this time) this motor seem's to be holding up well. From full speed to spinning the tire's in reverse on a normal road. I really thought i'd hear something snap, including my stock tranny, but it didn't. Guess I was lucky.
So a 5 mm shaft it is. Which will fit?(if any)
squeeforever
squeeforever's Avatar
01.10.2006, 05:02 PM
im assuming a feigao, nemesis, wanderer L would fit.
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
01.10.2006, 06:14 PM
Why not contact hacker usa about it? Not always the fastest I know but just don't tell them it's for an R/C Car (otherwise they scream bloody murder). I think they make 5mm shafts for the c50 cans, just not the maxx editions.
http://hackerbrushless.com/motors_c50.shtml
That should confirm that:) Hopefully those can's are the same dimension now
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
MetalMan
MetalMan's Avatar
01.10.2006, 09:42 PM
Doesn't the C50 Maxx use a 12s rotor? I've heard that it's just a 12s rotor in a larger can... Are my sources correct?
Sneeck
RC-Monster Custom
Sneeck's Avatar
01.11.2006, 01:49 AM
Thank's re-mix, when I get home from work this afternoon i'll measure up my c-50. Hope it will fit.
Serum
Serum's Avatar
01.11.2006, 03:15 AM
Heard/read that too Metalman.
