Help :( 8ight-T temps gone through the roof!! -
01.14.2010, 02:52 AM
Hi ALL,
Have had my 8ight-T for almost a year now and have had temps dialed nicely for a while now, motor hovers in the 155F range after a hard run.
I rebuild my centre diff last drive, and my front diff last night. I went up to heavier fluid to stop ballooning and now my motor temp has gone through the roof (198F).
Could be the heavier center fluid sending more power to the rear, therefore creating a heavier load on the motor and pulling more current during acceleration. The way it was set before sounds like it was in the sweet spot for that truck/setup. Could also be the new gears are kinda rough and need time to break in...IDK Just an idea.
30 does seem a bit heavy for the front. The heaviest I run in the front is 20 in my truggy
When I temped everything after running, my lipos were about 20F hotter than normal and I have noticed that one of them is puffed a little (hard case has come apart at the seam).
I'd bet on a bind in the drive train.. maybe the rear diff? How do the wheels spin when the motor is off? Is it super smooth and free? I highly doubt a diff fluid change would do more than +/- 5degrees.
