You could try a lighter fluid in the center diff. Maybe 7-8k? That would send less power to the rear wheels and be less likely to spin out in corners. Only downside is that you lose some straight line acceleration.
I think you mean understeer (front "pushes"). Make sure that mechanical travel is going to max as well as epa max. You could try to get more weight forward (if possible).
thicker front oil in the front will have slower entry, but fast exit, if you lighten up the center the front wheels drive more, but you can use the rear drive to whip the car around the turn, i found 7-30-2 worked out for my crt, the truggy really is a turd tho lol, i gained a lap on my times going to the 2.0 losi
I m at 7, 10, 2. I using slip diff that's y it's 10k.
I m thinking of 5, 10, 1. Wat u guys think?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
I drive a D8 buggy and I would rather have it under steer (push) than over. But if you want more steering entering a turn, soften the front suspension.
This is a good "article" on suspension tuning.
