running lipos in parallel with MM 2200kv -
09.28.2010, 10:49 PM
Hi guys i have a MM 2200kv, and i am running it in my G4-Maxx truck. I have two Venom 4s 25C 5000mah 14.8v lipos. So i want to run them in parallel; this way i can have 10,000mah at 14.8v. My question is this: the MM says that it can only handle 6s lipos with a max voltage of 25v... I want to know if i run my two batteries in parallel if the batteries remain at 4s or do i have to add them together giving me 8s? I have run them individual because i have been scared that i might blow up my esc. I know if i run the two batteries in series that the voltage will be 29.6v; so this is no good. So i am confused how to understand what happens to the cell rating when i run them in parallel: do they stay at 4s or do i have to add them together which will bring me over the 6s esc limit??? Please help.
I think you might be risking more by running them individually if the venom packs arent up to the task of providing the current needed for the speed controller in a heavy MT. I would run them in parallel asap. Make sure you check the wiring diagrams and get the parallel connection right, since running them in series could make for a lot of smoke. Maybe measure the voltage before you connect them up to the ESC before you make your first run to make sure you have 14.8V.
