Just got my LST-XXLe up and running....the pull away seems very bad, it needs quite alot of trigger to get going and then feels as if it gets a sudden pull away even though im trying to pull away smoothly. top end its a monster!!!!
its on a 5s Hyperion 35c LiPo.
Make sure the throttle endpoints on your transmitter are set to max and recalibrate the Tx to the esc. My only other guess is you're geared pretty high and its cogging at low speed then it rips once past that.
What version of the MMM is this? Is it the kind with the bullet connectors on the PCB? It could just be some connectors not making good contact which increases resistance.
The motor terminals have the female bullet connectors, the battery wires are soldered to the board. Tried changing the firmware and it's the same, my other MMM works just fine and dead smooth
So thinking I should just send it back to get checked out.....
