New E-Maxx looking for Lipo/BL advice
E-Maxx Hustler
New E-Maxx looking for Lipo/BL advice - 03.14.2007, 07:46 PM
Hi all,
OK, first post. I did a lot of research recently to try and find some recommendations. Of course, everyone has their prefs. I also read the sticky. Good write-up. What I am after is a fairly reliable, longer running, a bit faster, E-Maxx. I was thinking about the Feigao 7XL as mentioned in the sticky, but unfortunately, RC-Monster does not have any 7xl's in stock. (or 8xl's). They only have 9XL's with the built in Heat Sink. I was considering going to the Novak HV set-up but most advice points towards a custom set up. Bottom line, I would like something that is going to get me 30-40mins of Run Time and will not be too fast to be hard to handle. If someone can give me a "shopping list" of items I will need to convert my bone stock E-Maxx to Lipo/BL. Also need Lipo suggestions. BTW, I will be just using the E-Maxx for cruising around. Nothing hard core. I don't want to break anything:017:
Cheers,
Follow up.
E-Maxx Hustler
Follow up. - 03.14.2007, 07:49 PM
One more Q. If I go Lipo, I assume I would still use 2 packs, correct? I still don't quite get the 4S/2S thing so I was not sure if you would use two packs, or just one. Ie. 2-2S packs vs 1 4S pack.
Cheers,
coolhandcountry
coolhandcountry's Avatar
03.14.2007, 08:22 PM
If speed is not an issue. You would rather have run time. I would recommend
the 9xl of the 7xl. If you looking for long nice runtime. Go with the 4s about
8000 mah packs. 2 x 2s pack You will still have enough power to break alot of
stuff.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.14.2007, 08:26 PM
I'm not one of hte emaxx guys here.... others are more in tune to exactly what you should upgrade.
For batteries I would say a pair of 8000mah packs would be good... and will give you the big run time you want... should do 30+ minutes of solid runtime.
The emaxx is well suited to higher kv motors. The 9XL would be perfect for you in a center diff style truck, but you might not be able to get the gearing tall enough in a emaxx with a stock gearbox/motor plate.
See what others recomend...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
