Brushless Heavy Weight....
brushless BlackJack 55" Boat Suggestions? -
10.01.2007, 09:01 AM
Hey guys,
I've been playing with boats for a little while now.. I really don't have much experience with brushless boats..
I picked up a Blackjack 55" for around $400 from a buddy.. with everything except the Tx/Rx. I'm unsure which Motor to use for this baby.
Would the 2250, 2280 Lehners be too small for them?...
I will get a very low KV motor, say some where around 400-500 rpm/volt.
I will be running around 40-50 Volts...
ESC, I will be using 40160WK, Jeti Spin 200, or Maybe The Lutach ESC, if it get's here in time.. :)
So for that size boat, would I need to get the 3060 or 2230/1.5Y... well, if I need to get the 30 series motors, I might as well get the 3080... What do you guys think?...
I'm unsure how many RPMs those Gasoline Zenoah G26 engines run, whatever they run, I will try to match that rpm with my batteries and motors... I would like to use the Lowest RPM motors to achieve this.. I like to have the higher voltage stuff.
I'm sure someone knows something :)
10.01.2007, 09:46 AM
Good deal on the boat, congratulations. I have a Shockwave 55 and it is fast with the gas motor, maybe 40mph, and it is the sub surface drive model. I am currently converting it to the later model surface drive sytem. I will most likely leave it gas powered, let me know if you want to sell your motor/clutch/water pump, as I may be interested. Rumrunner racing forum is a good place to look around for a converted blackjack, the guys over there are knowledgable about electric boat stuff. We definately need pics of this project!!!!
10.01.2007, 04:30 PM
can't go on rum runners, they banned me for no reason...
but I would sell you the engine if you'd like, I have no use for it...
10.01.2007, 09:13 PM
me too.... banned:cause unknown
10.04.2007, 06:28 PM
what about using the Power Jazz 63V
10.04.2007, 08:16 PM
COol, that power Jazz looks awesome.. and only $400... I may concider that... but I would like more amperage though..
10.04.2007, 09:06 PM
there was a guy in my fe boat club running a 60" mono 10s2p set up and a lehner 3040 or 3060 i dont know, and it would do 60mph running wet with the most insane holeshot i have ever seen
10.05.2007, 04:35 PM
60 MPH is an easy goal for me to achieve... any faster I wouldn't have enough room to play on my lake.... I really like the 3080... yummy...
But lehners stoopid customer service is making me lean towards a neumotor...
10.09.2007, 11:45 AM
That's a lot bigger than any of my boats, I think 22 series is too small for a converted nitro boat of that size 3060 or 3080 would do the trick, but if I lived in the US of A I would go for a Neu bam for sure, the wind depends on the ESC you decide on as you want HV, 20-25k RPM would be a good target, a tuned Zenoah or Mathe will get close to 20k but there's no reason an electric shouldn't do better.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
