How do you guys mount your 9920 ? -
09.01.2005, 05:30 PM
Just working out the layout for my BL MGT, new chassis on route (a steal off ebay) so i can hack away to my hearts content & mike is sorting me a centre diff, theres loads of room, got a few ideas on battery placement & i can keep the esc, rx, ubec, etc all on the centre line easy.... im looking at putting the ESC (probably the 9920) behind the motor on a nice flat bit of chassis but have noticed the 9920 looks basically just shrink wrapped, not what im used to with an ESC, so how do you guys mount it ? is it zip ties & double sided tape ? or has someone got a more technical answer ?
I use zip-ties. If you use double sided tape I would use servo tape. Other kinds just seem to peel off, you can also try velcro. I prefer to use velcro but in some situations you can't.
I use velcro, servo tape or zip ties ..... or all at once:) A little padding won't hurt, because the electronic components on the bottom are just protected by the shrink. Some foam are whatever
Here's an old pic of my Revo, when I still had the 9L. Between the mount and ESC you would find a strip of thick velcro. I also use 2 zip ties on this one.
Cheers guys, so my usual double sided velcro, a bit of padding & maybe a zip tie....... though serum, if you wanna knock up another of those mounts you made for the lightning ;)
Thanks Serum, I see. No big chemical magic involved, eh?
I just removed purple ano from a G1 Gorilla chassis, used a solution of NaOH. Worked like a charm.
Like I said in my first post. It's a good idea to use some sort of padding when you mount the ESC directly on the chassis of an off-road RC. A member here once damaged some components.
Yes, padding is NEEDED! I broke a part on the bottom of my Warrior 9918, even though I was using velcro on the bottom, and zip ties! Foam padding would be the best, IMO, along with zip ties.
