Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
MMMv3 ESC package question and some other stuff
Aceldama
Aceldama's Avatar
MMMv3 ESC package question and some other stuff - 04.23.2009, 03:24 PM
I've finally grown tired of waiting for the CC/Neu 1800kv motors. And to be honest 1800kv is a bit on the high side for 6s anyway. So I'm thinking the best motor for my 6s truggy is probably the Medusa 36-70-1600 w/heatsink-clamp.
That being said, I'm wondering if the MMMv3 comes with anything?. I'm particularly interested in the CastleLink.
And I guess while I'm at it, does the Medusa come with any connectors installed?
Thanks.
MustGoFaster
MustGoFaster's Avatar
04.23.2009, 03:30 PM
Yes it does.
Aceldama
Aceldama's Avatar
04.23.2009, 03:52 PM
Originally Posted by MustGoFaster View Post
Yes it does.
Excellent, thanks. I was worried it might be included in the combo only and not if I purchased the v3 on its own.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.23.2009, 04:24 PM
If you order from Mike and order from the combo page you don't get the 6.5mm bullets and wires but save a little bit even after purchasing them seperate. The Medusa doesn'tr come with any connectors attached.
Aceldama
Aceldama's Avatar
04.23.2009, 04:35 PM
So If I were to buy the MMMv3 on it's own, I could just get the 6.5mm bullets and put them on the Medusa and I should be set?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.23.2009, 04:37 PM
Yes but you will need to add some wire as well, the leads coming out of the Medusa are only about 1.5" long
Aceldama
Aceldama's Avatar
04.23.2009, 04:39 PM
Ahh, I see what you're saying. I was just checking the Medusa Research page to try and find out how long the leads were.
Aceldama
Aceldama's Avatar
04.23.2009, 04:47 PM
I guess while I'm here asking questions:
Will the .25 inch brake spacer fit the Medusa motors? I figure there might be an issue with bearing carrier clearance. Then I'm wondering if they even require the brake spacer since the can isn't very big.
04.23.2009, 09:49 PM
More than likely a clearance issue with the front bearing hub, but you could drill out the middle of the spacer to make room. Im thinking about the spacer for my medusa as there are only 2 25mm spaced mouting holes- strip one of those out and you're buggered. Fixing the spacer to the front only gives you 2 spare holes again, but if you strip them out, at least it isnt on the motor. I believe the spacer is 36mm diameter, same as the motor, so its only any use on a neu or hacker or other finned motor towards the purpose of clearing a brake disc or caliper etc.
Aceldama
Aceldama's Avatar
04.23.2009, 11:46 PM
Thanks for the tip. I guess aside from the mounting hole insurance it doesn't make any sense to use it for mechanical brakes, which is why I was interested in it.
Now I just need to decide if I need the motor clamp or not.
