Racing 1/8 Buggy on 3s
pumpkinfish
Racing 1/8 Buggy on 3s - 05.04.2009, 09:40 PM
Does anyone race their 1/8 buggy on 3s? If so, what capacity packs, motor and general run time are you seeing? My friend and i were discussing setups and he asked why I am running 4s. He said it looks like I have a lot of wheelspin on our dusty track and was wondering if the 3s setup would help. Sorry if this has been discussed before. Since I am now shopping for a new motor, I was thinking now may be the time to try something new.
nitrostarter
nitrostarter's Avatar
05.04.2009, 09:45 PM
I'm running a Jammin X1 conversion, 2650 MMM combo, on 3s 4900 rhino's, 16/48 gearing. I get 12 minutes of track time with this setup. All I need is 10 minutes.
N. Rustler conversion
pumpkinfish
05.04.2009, 10:03 PM
I would need 15min for race and probably an extra minute or two for warmup and waiting for the nitro guys who flame out, lol! What speed/rpm do you target?
D8 Driver
Talking 05.06.2009, 11:55 AM
i am curious, how are these" rhinos" lipo packs, do they last long, or puff up? i heard that they are not as good as the flightmax batteries. can you tell me about the pros and cons of these "rhino" lipos. thanks
05.06.2009, 12:18 PM
Construction quality of the rhino packs is superior to the flightmax packs. Not sure on cell performance or lifespan. Most who use them seem to have good results.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
05.04.2009, 10:18 PM
It can be done on 3s but I would highly recommend at least 4s. On 3s everything will run pretty hot if you want to keep up with the other guys. You'll get more runtime for a given capacity on 4s too...
nitrostarter
05.04.2009, 10:24 PM
It also depends on your track configuration. I race on a small tigh track, only one straightaway worth full throttle. I chose 3s in order to shed some weight. It does get a little hot towards the end of the race but she's ok. And all we run are 10 minute mains.
Now if my track was a little bigger, I would definitely spring for the 4s setup. This setup would be more efficient if geared for the same 42mph(12/48 in my setup). This would still provide great speeds but also longer runtimes.
What packs are you running?
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.06.2009, 03:01 AM
not with the new 2200kv combo your getting
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
nitrostarter
05.06.2009, 10:04 AM
Ah, but thats going in my Jammin Truggy on 4-5s.
pumpkinfish: I timed my practiced yesterday. I ran 16/48 with the MMM2650 in my Jammin X1 buggy on 3s 4900 Rhino 20C packs. Continuous track running yielded right under 13 minutes before the LVC on the MMM hit. I'll try to get a video soon. I have plenty enough top speed for my track. I'm looking into dropping down the pinion to either a 14T or 15T. That should yield more run time as well.
pumpkinfish
05.05.2009, 05:12 AM
Right now I am running 4s 5000mAh Neu packs. It is just that our track gets so dusty at times I am trying to figure out if the lower power setup would be beneficial.
nitrostarter
05.05.2009, 05:21 AM
What tires are you running? In real dusty situations, it would help to run a larger stud like CrimeFighters. You may just want to turn the throttle EPA down to 80% or some % and give that a try before going buy new packs and pinions.
pumpkinfish
05.05.2009, 05:22 PM
We usually run crimefighters, bowties or "Bowfighters" -- crime in the front, bows on the rear.
Semi Pro
Semi Pro's Avatar
05.05.2009, 06:22 PM
i raced my lightning LSP truggy with the novak 6.5 hv on a 3 cell 8000mah pack
it was just a cobbled together truck, but it worked out well
BUSAFIED
05.06.2009, 02:22 AM
hyper 7
Neu 1515/1.5D/F
MMM
NeuEnergy 5000mAh 11.1
14 or 15t pinion
get about 15-18 minutes runtime
nitrostarter
05.06.2009, 12:16 PM
I find them to be pretty good. I've got a bunch of cycles on them. Good runtimes, good punch.
Con: I find one of my packs are starting to discharge unequally now for some reason.
Otherwise they are nice for the price. These are the same packs the "round" used to take his E-Revo to 76.7mph, he's a member on the Traxxas forum. I bought these from him.
