My MMv3 is back, thank you Castle, BUT IT DOESN'T WORK ! :(
nuz69
nuz69's Avatar
My MMv3 is back, thank you Castle, BUT IT DOESN'T WORK ! :( - 06.02.2010, 08:00 AM
Forum bug, I can't edit my last thread, so I made a new one...
Today I mounted my ESC just received yesterday from Castle warranty repair. I configured it with Castle link without any issue. Here is the problem :
1/ When I plug the battery, the ESC turns always ON, no matter the switch position, the switch seems to be internaly shunted. I checked it by removing the switch, the ESC turns ON immediatly after pluging the battery in.
2/ No matter S the battery has, the ESC do the little music, then 2 "biiip", then nothing. The fan turns and the 3 LEDs are "biiping". I checked the battery voltage and try with all my 10 batteries...
Maybe there is something else internaly shunted... I don't recognise the problem LED sequence in the post "definitive LED meaning" :( :(. I think I have to contact Castle support to make a new support request :(. Unless someone here has already had this kind of problem...
Fortunately, I have another MMv3, so I will be able to run , but for my first experience with Castle support, it seems that I didn't have luck :(
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
