LipoSack Material? -
09.21.2010, 12:32 PM
What material, specifically, are those LipoSacks made of? And where could I get the raw material?
Since my basement got wrecked, I keep everything in the garage now, and with the varying temperatures, I don't want to keep my lipos in there too. I've been putting them in a Liposack and storing them in a toolbox in my living area. However, I have too many lipos for one sack, and I'd rather not get numerous sacks. So, I want to get some of the sack material and make my own compartmented storage box, complete with charger/powersupply area. Makes it easier for travel.
09.21.2010, 12:55 PM
I just use a fireproof document security safe.
09.21.2010, 12:56 PM
Ps pretty sure you could just use a large fire blanket.
I have a liposask, not positive of the material used, but I plan to get a military ammo can to store my lipos in when they're in the house.
You can get em for around $10 at gun shows, and I trust them a lot more then the lipo sacks.
09.21.2010, 01:36 PM
X2 on the ammo cans. thats what i use, i even made 6 compartments in it by tack welding some dividers in it, that way if one lipo goes off there is a less chance it will take out the others. I also drilled some tiny holes in the lid so if one does explode it can release the pressure. Hopefully it works, but hopefully I will never have to find out!
Soldermaster Extraordinaire
09.21.2010, 01:45 PM
My guess would be a tight-weave fiberglass mat... That's what it looks like in the pictures I've seen.
09.21.2010, 01:52 PM
09.21.2010, 03:00 PM
Originally Posted by nitrostarter
Mark should know...he's the owner/inventor.
09.21.2010, 01:56 PM
Lipo sacks seem to be made of Fiberglass or ceramic fibers with layer of high temperature silicone to keep fibers in place..
A metal box with a inner layer of "3m Nextel 312" should be more than enough.
I use nextel 312 on my turbo manifolds and that thing is Tough!
09.21.2010, 02:14 PM
Wimps. I sit mine on a shelf in my bedroom- death by glory if it ever comes to it...
09.22.2010, 07:42 AM
damn right neil! i sit my lipos next to 5gallons or fuel and a set of fireworks in my garage... that way i know if the lipos blow up, there will be an indication of an explosion and a spectacular fire work display!
But seriously... i think im going to find a metal box as i just dont trust the lipo sack!
Fiberglass cloth eh? All the cloth I have seen is meant to have resin added. At least it gives me a place to look.
I have a container already, but if a lipo does go up for whatever reason (I do still have a certain ill-reputed brand lipo), I'd like to 1) prevent the other packs from going up as well, and 2) not get so hot that the metal can's surface doesn't combust whatever it is sitting on. I know there'll be tons of smoke, but if I can contain any flames and the majority of the heat, the container can be moved outside in short order.
The storage version of the liposack is kinda what I'm looking for, but it makes for a rather large item to move, and is still a "soft" container. My idea is to use any toolbox with fire-proof material lined compartments that I can slide lipos on-end with enough room at the top for the wires. Simply shutting the toolbox "caps" the compartments (but still allows some venting).
Neil: Death by glory or any other means is not an option. I don't know what I would do if my wife or kids were killed, or rendered homeless, because of a hobby. This is a case where an ounce of prevention is worth ten tons of cure...
09.21.2010, 08:48 PM
For example ..
http://www.agismfg.com/html/cloth.ht...Fcde7AodLUGxFg
You can also use any exhaust wrap from ebay ...
Fat Kid Engineering
09.21.2010, 03:02 PM
Look at HaborFrieght and Tool for a small welding blanket, it's the same shiz and should be had cheap ?
09.21.2010, 03:14 PM
Good idea bondo! Did a quick search and found three fairly inexpensive blankets. Might have to swing by sometime and check them out in person to make sure it's what I'm looking for. 1000*F should be sufficient...
Hybrid Mode
