locking tranny in 2nd
entjoles
locking tranny in 2nd - 02.05.2007, 07:34 PM
i use a center diff with front and rear brakes, my ? is if i lock my tranny in 2nd and still use a servo for brakes will it work properly? im thinking no but could use your help
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.05.2007, 08:02 PM
You lost me.... is it a center diff or center tranny? Revo?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
jhautz
jhautz's Avatar
02.05.2007, 08:16 PM
sounds like a revo tranny with the optional diff installed.... Right?
to make it...
or break it...
Silent...But Deadly
entjoles
02.05.2007, 10:04 PM
yes revo tranny with center diff installed, if i lock the gears into 2nd will the diff work properly?
BP-Revo
BMW M Power!
BP-Revo's Avatar
02.05.2007, 11:00 PM
It should be fine - the two speed assembly is seperate from the center diff assembly.
entjoles
02.05.2007, 11:04 PM
but with the hv maxx i cant turn off the brake function, so it will stop the gears, right?
02.05.2007, 11:11 PM
Yes, if you lock the tranny in second, the motor will stop the truck. And you'll have reverse.
BigSushi
02.07.2007, 10:46 AM
Will you still be able to use the Traxxas Center diff with the 2nd gear and still be able to use the motor brakes and reverse?
02.07.2007, 11:47 AM
Yup. First and/or second gear have nothing to do with the gear that drives the center diff (it's a seperate gear). I am using locked 2nd gear with a center diff (although it's a custom one, not the stock one).
To lock the tranny, you can either use the little adaptor by b0gh0s, or you can easily do this mod to do the same thing.
