Looking for Info on 1/8 Scale e-Conversion
bwillhite
Question Looking for Info on 1/8 Scale e-Conversion - 03.25.2007, 01:54 AM
Hello,
I am wanting an electric 1/8 scale buggy, but I am having trouble finding info on the conversion process. I am a R/C Airplane/Heli flier who has started getting into R/C cars. I am all electric, some of my airplanes are 2000+ watts. So electric isn't new too me, just cars.
There is a local track I want to drive at, everyone there is running 1/8 scale buggies or truggies. I have drive my 100% stock e-Maxx there, but it is lacking!
I was thinking about the Ofna 1/8 Ultra MBX R2 Buggy 80% Prebuilt kit, is this a good conversion canidate?
Thanks
Brian
03.25.2007, 02:03 AM
Pretty much anything can be converted really. Some of it is a little creativity, some of it is how willing you are to do a little fabbing. Mike (site owner) has several center differential mounts/motor mounts he's made for various people here (myself included).
Sometimes, there are some "obstacles" where you have to do a little thinking to overcome them. For instance, I'm converting a CRT .5 truggy and am having trouble with the center diff. It's just a matter of finding the perfect thing that will work.
Basically, first strip the buggy of all Nitro parts. Then, see how much room you have for batteries, motor, ESC, UBEC, receiver, etc. Don't forget than buggies can be somewhat limited in room height-wise, especially on the sides and front where the body sits kinda low. Most buggies are VERY similar and there are quite a few people here that have already done some. I've done an Ofna Hyper 8 buggy (go to the last several pages) and am quite pleased with it.
jnev
jnev's Avatar
03.25.2007, 02:28 AM
Mike just actually made a motor mount for my converted buggy, and I'll tell, as will most of the other members, that he does some incredible work. You just have to think outside the box, and choose how and where you want things mounted to the chassis, etc.
Aragon
03.25.2007, 07:50 AM
Hi
Like you I'm also from the eheli scene. I'm still busy with my conversion. I chose a Jammin X1-CR to convert and bought the FTE kit (rolling chassis) a while ago to see what all was involved. Like BG said, you really need to get the car and get it to the point of a rolling chassis so you can see what all is needed and how much space you have to work with.
squeeforever
squeeforever's Avatar
03.25.2007, 10:49 AM
You might want to go with the Jammin X1-CR, Like Aragon did. Mike just make a motor mount for the CRT, which if I'm not mistaken, will fit the CR as well.
bwillhite
04.08.2007, 10:22 PM
Thanks for the replies, been out of town on business.
Still up in the air on my project!
Might just spend some money on my old e-Maxx.
Brian
jhautz
jhautz's Avatar
04.09.2007, 07:16 PM
Originally Posted by bwillhite
Hello,
Thanks
Brian
If you still want to do the Ofna MBX R2 I have one sitting at home already converted. Its a rolling chassis but has a motor mount and carbon fiber battery tray already made for it. The tray is designed for lipo 3700mah, 4350mah , 4900mah, or 5000mah Enerland cells. I was running it on 4s track and 5s bashing.
Right now its just a rolling chassis cuz I took the electronics out of it and put them in my Matrix. Let me know if your interested. All you would need to do is get a motor and electronics for it and you would be ready to roll. I added some additional chassis bracing to it cuz it seems a little flimsy to me. The chassis braces could be done better but its a very solid start. The thing is practiaclly brand new only 4 or 5 packs have been run on it. A couple hours total run time maximum. I even have a ton of spare parts for it. (just about enough to build a 2nd complete buggy) I built it and ran it a few times and then was wanting something a little higher end and I found a good deal on a Cen Matrix rolling chassis so I jumped on it and converted it.
I was actually thinking about tossing it up on ebay in the next few weeks. Let me know if your interested.
BTW: I'm on the road all week this week for work so I wouldn't be able to get you any pictures until next weekend. But its not going anywhere.
to make it...
or break it...
Silent...But Deadly
bwillhite
04.09.2007, 11:03 PM
Very Interested! Send you a PM.
Brian
cmain
05.11.2007, 09:24 AM
I am also looking to convert a 1\8 to race at the local track what motors are good. I know the 9l works well but was wondering if there is any other good choices. I will be running a mamba max on 3s lipo mabey 4s.
thanks
05.11.2007, 09:48 AM
Most people here run an XL size motor, or a 1512/1515 Neu motor, or even an LMT (Lehner) motor - any of the bigger ones. The larger can will help with heat. Since you are using the Mamba Max, I would stick to 2 pole motors like the XLs or the LMT 19xx. The wind (turn count) is determined by the battery voltage you want to use.
cmain
05.11.2007, 10:36 AM
thanks:) any idea about how much run time I could expect from a 3s 6000 runing a 9L /xl in a kyosho 777 geared 14/46 or so. just wondering if 6000 is enough or should I go bigger. thanks again
gixxer
gixxer's Avatar
05.11.2007, 10:48 AM
I would go to 4s. With a 9xl motor and a 6000mah pack you should be at about 20 minutes at a race pace.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
cmain
05.11.2007, 11:04 AM
I thought about it but A freind has 3s and is almost equal to the nitros laks a little on top but has more tourq. I figure if I went 4s it would be a nitro killer and they would make us start a new class which would suck.
20 miniutes would be perfect I may go 8000 just to be safe.
small vid from the track it will be raced at
http://www.youtube.com/watch?v=VEgTXY7trLw
gixxer
gixxer's Avatar
05.11.2007, 01:55 PM
go with a higher turn motor then. seriously 3s will be hard on your batteries to get the power you will need. 4s and a 9xl should give you more torque and about the same top end as a nitro.
