That spur gear didn't last long...
Toon
Talking That spur gear didn't last long... - 08.17.2005, 06:02 PM
A couple of weeks ago I stripped the RRP spur gear that I have been using in my 9L brushless E-Maxx for a while now. As it's almost impossible to get aftermarket E-Maxx spur gears over here in the UK, I decided to try a stock one.
I bought the Traxxas slipper rings, pegs, and a couple of 66T spurs. I fitted one, set the mesh, and cranked the slipper down tight. The spur had a bit of 'wobble' in the rotation, but the RRP one didn't sit true either, so I wasn't too concerned. I fitted the stock gear cover as well to try and reduce the chance of a small rock getting caught. I took the truck out for a run, and it was going great for 2 minutes. Then the truck slowed, and started making a grinding noise. I brought the truck over, took the body off, and saw lots of small pieces of black plastic on the chassis around the tranny. There was the smell of melted plastic, and even a bit of smoke coming out of the spare motor plate opening!
Needless to say, the stock spur had smoked itself. I was just surprised at the amount of damage that had been caused in such a short amount of time, even with it fully tightened! :L:
Once the Ofna nylon 51 tooth spur gears are in stock, I will order a Strobe kit. I'm running 15/66 at the moment, so 12/51 should be OK. I also bought a Revo a couple of weeks ago, and the tuning 'issues' I am already experiencing with it will keep me occupied until then... :rolleyes:
Gustav
Gustav's Avatar
08.17.2005, 07:25 PM
Hey Toon, i don't suppose your'e in the North East are you with a name like Toon?
Serum
Serum's Avatar
08.18.2005, 01:25 AM
It is a Dutch name..
Gustav
Gustav's Avatar
08.18.2005, 10:04 AM
Oh right,interesting.
Toon
08.18.2005, 03:15 PM
I'm not Dutch, I know that much... :L:
Gustav was close though, my name is derived from the football (soccer) team I support. I am not from the NE of England, but the team is based there. :D
Serum
Serum's Avatar
08.18.2005, 03:33 PM
Well trust me.. Toon is a dutch name too..
dabid
08.18.2005, 04:18 PM
If it ain't Dutch, it ain't much! :L:
I'm 1/2 Dutch, just so y'all know.
cabking
08.19.2005, 12:34 PM
You won't look back with the Strobe slipper Toon.
Ive had one for months now, with little or no wear on the spur at all.
don't forget the Sprong either ;)
Serum
Serum's Avatar
08.19.2005, 12:52 PM
that Sprong won't work on a gmaxx chassis..
Big salute Dabid... ;)
Gustav
Gustav's Avatar
08.19.2005, 01:19 PM
Would the sprong work if he just used an e-maxx motor plate?
Serum, I sure would like to see a pic of the underside of your Savage.Is it a whole plate with the sides bent up or are they just plastic buggy thingemyjigs?
Is there a pic on line somewhere i could check out?
Also, i've still got the BigMaxx and shulze.I was wondering whether to just e-bay the controller and try the motor with the 160amp MGM on 16 cells.
Did you think the motor itself was any good or should i just sell them both?
Serum
Serum's Avatar
08.19.2005, 01:40 PM
here you go!
More pics can be found here
Toon
08.20.2005, 05:26 PM
What exactly is the 'sprong', and what does it do?
rchippie
rchippie's Avatar
08.20.2005, 05:30 PM
The sprong replaces the stock spring. It also when tightend helps to keep the sur from woobeling.
REAL MEN RUN BRUSHLESS
Dafni
Dafni's Avatar
08.20.2005, 05:31 PM
It replaces the slipper spring, and I was told it holds the tension better (locknot stays in place longer)
cabking
08.20.2005, 05:32 PM
It replaces the waffty spring on the slipper.
It stops wonky spur syndrome and gives somewhat better control of the slipper.
you will have to moddify the gear cover if you use it. :)
