5MM Bore Pinions. -
04.08.2008, 10:02 PM
I'm getting a 3905 E-MAXX it's the new one and a Novak 6.5 ESC and Motor setup.I was looking a towerhobbies at the spurs for the new E-MAXX and there using a .8 module pitch spur gear I seen it's molded on the spur gear .8 Now what I need to know is will the mod1 pinions that rc-monster sells mesh up with the .8 spurs.Novak also says on 16.8 volts to start with a 12 tooth pinion and move up from there the rep for Novak told me you can go as high as a 14 tooth pinion,he said running in grass maybe to much for it with a 14 tooth pinion.I do not have a track and will mainly be bashing.
