Brushless monster trucks
Brow
RC Drag racer
Brow's Avatar
Brushless monster trucks - 08.30.2008, 11:29 PM
I am looking to end up with a brushless monster truck and am leaning towards a Savage second hand and then convert it if I can't find one for sale already done. I am also looking out for any bargains in other trucks, such as Assoc MGT and Losi LST2.
During my research I have read all the threads about buying new, converting and buying electric new. I want a large truck (1/8th scale) because I think they look better bigger and will mostly be bashing it.
Now to my questions:
What scale are the E-Savage and E-Maxx?
Are they the same size as the Savage SS and T-Maxx?
Is the E-Revo the same size as the Nitro Revo? (just an electric conversion)
Thanks
Brow
jnev
jnev's Avatar
08.30.2008, 11:52 PM
The E-Savage and E-Maxx are considered 1/10 scale, however, the e-maxx (no experience with e-savage) is as big as the T-Maxx and both are a little smaller than a Savage. E-Revo is actually a little longer than a nitro Revo.
If you want the biggest and beastliest truck on the block, I'd say go for a Savage with a FLM extended chassis.
Desmo
08.30.2008, 11:53 PM
Thanks
Brow
not to get to into the different versions of each but real quick here you go,
1/10 scale so they say
E savage is the smallest and not the same as a nitro savage
old emaxx, tmaxx, 2.5 revo are the same size
new emaxx, 3.3 tmaxx, and 3.3 revo and e-revo are the same size and alittle longer than the early ones
1/8 scale
the savage, mgt and lst are about the same and a little bigger than the maxx trucks
As the owner of several emaxxes, tmaxxes, lst's, ek4-s2, 1/8 buggies, etc. Early emaxxes are cheep right now but you'll spend allot in upgrades to handle the extra power. Personally I would go for a new e revo. Its all done for you and parts are as easy as the local hobby shop.
here's is an emaxx next to an lst
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
08.30.2008, 11:58 PM
I would have to agree and go with an E-REVO. It is a bit bigger than a REVO 3.3 and comes ready to handle the power of brushless (except the pre glued tires). I have one and am running a Tekno Neu 1515 2.5d/f and a MMM. The only other mod I have is the maximizer beadlocks and badlands MT tires. Nothing has broken yet even after several "bad" landings and cart wheels!
08.31.2008, 12:12 AM
+1 on the new erevo. Seems well built, and handles better than an emaxx. I run a 1515 1.5d on 4s in mine, and it handles that power and 45mph just fine. The lst and savage are bigger (savage is not much bigger) but they are not so easy to build electric...
Desmo
08.31.2008, 12:16 AM
The E revo was 399.99 in my local hobby shop. My emaxx has that alone in upgrades. We won't even get into to my E lst conversion.
08.31.2008, 12:28 AM
The e-lst conversion is not too bad. I have the forward only tranny with the internal swap for better ratio. I use a "the dude racing" single speed hub with a 59t tin spur and a 24t RCM hardened pinion. Problems are the lack of a prefabbed motor mount (until the dude gets his ready for sale) and a spec battery tray. I intend to use motor brakes, so the brake servo will be gone, and the battery tray will go between the rec box and the tranny. I will mount the esc where the fuel tank sits... Will have to make a battery tray, use some kydex like always.
Desmo
08.31.2008, 01:10 AM
I didn't go the standard route with my lst. Mostly just time. $ wise the most expensive thing was the esc. Even the LST2 chassis was less than 100.00. It handles so much better than the early emaxx that I want to sell my emaxx but I have to much in it I would go with an e revo if I was starting out right now.
Its changed some more since these where taken.
Mozzy
Mozzy's Avatar
08.31.2008, 01:12 AM
I'm avoiding the motor brakes on my E LST as it's alot of truck to stop.
The LST isn't all that difficult to convert. As someone mentioned the most difficult part is the motor mount. I designed my own, but, still haven't bothered to get it machined up.
Too sick & lazy. As soon as I get it done, I'll post pics & hopefully vid. Had a Quark SSB MK III in it originally, but, fried it doing some test runs with a high kv motor (6XL)zip tied into the chassis on 4s. It worked a treat till the ESC went awol.
Now going to try MM & a Feigao 8XL on 5S(thinking should've got a 9XL or 10XL). My mount is designed around the Feigao diameter can using the RC Monster heatsink.
As the guy's have said, for simplicity, the E Revo is probably the ticket & it's also going to be new with no cracks or worn out parts if you buy new.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
Brow
RC Drag racer
Brow's Avatar
09.06.2008, 09:50 PM
Thanks for all the help and info.
I have seen quite a few new trucks now in stores so I know a bit more about what I am looking at. I saw a Thunder Tiger MT4 and really like the look of it as a truck but it looks difficult to convert (ie custom).
I have got onto a deal for a new Savage X SS kit $350 (Australian dollars) without engine, tank, clutchbell, engine mount, exhaust from a local shop (normally $600 for full kit). I know I might be able to buy a full kit and sell off the parts for a cheaper final price but this is easier, no shipping cost and I need less cash up front.
How does that sound to you all?
Also Lincpimp, sending you a PM re Kershaw mount.
Brow
coolrunnings
09.06.2008, 09:53 PM
I think the mgt is a pain to convert so is the lst, I don't think mike makes conversions for those trucks...just about everything else though.
traxxasrevony
09.06.2008, 10:09 PM
the mgt was super easy i just took my mmm 8xl out of my revo because i blew the tranny again. all i did was remove the nitro mount build aluminum plate that bolted to the chassis but i put small spacers under it to keep it directly off the chassis and driller 4 holes in it to bolt the flat part of the rcm revo mount to. then put the pinion on and away i went. i need a smaller gear though as i have motor temp problems. im going to buy a tekno electri clutch to run a cb on it because i have alot of them to work with. then im going to buy the tekno kit for the revo to run the clutch also to try and save the tranny some abuse and also get a 9 xl for the mgt and put the 8 back in the revo.
coolrunnings
09.06.2008, 10:50 PM
Cool! But I have a buddy here in my home town that has a mgt but can't really make anything home made you know (not and have it work...lol) so I'v kept an eye out for a conversion to recommend to him but havnt seen anything.
traxxasrevony
09.06.2008, 11:29 PM
i might be able to get a few pics tomarrow that you could show him its super easy to do
stum
09.07.2008, 12:27 AM
E-REVO is the only way to go here.. mine has a stance as wide as any 1/8 truggy, not to mention being faster and as capable on the track.. I race truggies every week and end up in the top 5 or 6. I beat myself out of being in the top 3 (getting too anxious), but the top 2 are pro drivers so... They have me beat by a second per lap still.
Here is a shot of her (17mm hubs and 1/2" offset holeshot tires are pretty much required for racing). Here is some action... sorry this is a bit old, but I have not done any video recently.
http://www.youtube.com/watch?v=vP4l4QEMB2Y
