Preventive Maintenance
Benji
Preventive Maintenance - 02.12.2010, 12:56 PM
Hi,
I just performed full maintenance procedure to my Brushless XT8 Truggy.
I replaced the oils on the Diff’s, filled up missing oil in the shocks and checked the bearings condition. Last time I did that was 3 month ago – total of 5 hours of run time on the track.
No major issue found but I did noticed that the oil in the diff’s become very thick and dirty.
In addition to the above I’m cleaning my Truggy after every session on the track, looking for loose screws and cracked/broken parts.
What are the maintenance intervals for you guys? 5 hours between preventive maintenance is good enough?
02.12.2010, 01:21 PM
What is this "maintenance" of which you speak?
I usually just run it until something needs to be done. I'll give it a decent glance every once in a while to make sure nothing is rusty, bearings are good, shocks are smooth, etc. If I run in wet conditions, I might dab a little WD40 on some places. It seems diff oil gets dirty after 0.0005 seconds of running, so I replace the oil maybe once a season. Same thing with shock oil. Yeah, those parts would last longer if maintained better, but I usually break something before it gets to that point.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.12.2010, 01:57 PM
My Bash stuff; Befor every run I check steering,gear mesh and look for lose hardware/parts. Just takes a minute, Other than I run them till something breaks or causes a problem of some sort.
My Track stuff; Same as above but give everytning a solid going over the day prior to going to the track in case a issue is found and needs addressing .
Regualr maitinance ; Twice a year I go through everything on each RC, check replace bearings,worn cvd's,pins etc rebuild diffs and shocks blah blah blah.
bdebde
That's All Folks!
bdebde's Avatar
02.12.2010, 04:14 PM
I do about the same.
bryan
bryan's Avatar
02.12.2010, 07:10 PM
When i brake mine i try to convince my wife that i need a new one and i could use this one for parts.Cant blame me for trying,but it doesnt work.
George16
Supermaxx
George16's Avatar
02.12.2010, 07:44 PM
I give mine a cleanup after each day or bashing. For the diffs, shocks, bearings etc. I usually tear it down during the winter months (one truck at a time) and it goes to the dishwasher for a thorough cleaning.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
OZ-RUSTLER
OZ-RUSTLER's Avatar
02.12.2010, 07:51 PM
That a great idea. Sure beats pulling all apart,soaking in degreaser and then using an old tooth brush.
Excuse me now while I go convince my GF.
George16
Supermaxx
George16's Avatar
02.12.2010, 08:06 PM
Just make sure you use cold water for aluminum parts. I made my mistake using the sanitized wash on my gmaxx and the hot water dulled the aluminum parts.
Revo with OS .18TZ
02.12.2010, 10:56 PM
+1 for that idea...I just need to make sure the wife is NOT around when I do this. Being a compulsive neat freak, she would lose it if she saw me putting rc parts in the dish washer
