Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Is there normal for the drive cup to wobble abit?
superek4
superek4's Avatar
Is there normal for the drive cup to wobble abit? - 11.26.2009, 06:48 AM
I notice my slip diff's drive cup wobbles(can move up n down like 1-2mm) so I took it out n check the cups. Hv not open it yet but is it wear n tear? Must I change the cups?
The bearings is still ok.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.27.2009, 03:33 PM
If the diff outdrives are wobbling, it sounds more like the endcaps are worn. 1-2mm of play is pretty excessive movement. I grease my outdrives and haven't worn out any caps, but I do have steel endcaps available as an option parts - they are about 2x as heavy as the aluminum caps, but are hardened steel and should last pretty much forever. :)
wallot
wallot's Avatar
11.27.2009, 04:26 PM
Mike, whats twice as heavy in grams? (or ounces or any other medieval unit you keep using )
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
RC-Monster Mike
Site Owner
11.28.2009, 01:23 AM
The front and rear cap made from steel weigh a total of 30 medieval gram units(1.06 medieval ounce units). The stock parts weigh a total of about 10 medieval gram units, so the steel parts are actually 3x as heavy(just weighed the parts) . :)
_dV
03.22.2010, 04:22 AM
medieval what now? what is the weight of the whole slipperential? (preferrably 46t mod 1 with both steel endcaps, incl bearings if it's easier)
also, what is the total width from outdrive end to outdrive end? ..cheers
