Go Back   RC-Monster Forums > Support Forums > Team Tekin
rx8 - strange behavior
wallot
wallot's Avatar
rx8 - strange behavior - 08.03.2010, 01:47 AM
Can anyone explain what really happened?
I got t8 motor from service and needed to test it along with my new CC1518. So I connected my good old RX8 to the T8 motor and everything worked, I disconnected battery, disconnected the motor and connected CC1518 and of course the battery and nothing. Not a single beep, no LED. HMM I tried my backup RX8 and no problems. So i tried to connect the original RX8 to hotwire and nothing. Hmm dead. How could this happen. I did not short any wires as I use EC5 connectors everywhere. Was already looking for a new ESC when I decided to try the RX8 again (4 hours later). And it worked. Connected it to the CC1518 and everything is ok. what is going on? Ghosts?
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
BIG-block
08.03.2010, 05:25 AM
Might be a bit of a long shot but I have seen people that have had similar problems and it turned out that there was components that have broken loose off the board. Apparently it's a reason why Tekin has made the new cases to combat the issue of components coming loose off the board during impacts.
That isn't my pic but it might show what i am talking about. The guy with that ESC had same problems as you are describing.
wallot
wallot's Avatar
08.03.2010, 10:26 AM
I guess I will have to open it a check if everything is OK. I wanted to do it yesterday but was too lazy looking for small phillips screwdriver :)
Radek
*EX-10 Eurus*
TekinTeamMgr
TekinTeamMgr's Avatar
08.11.2010, 10:49 PM
I'd like you to disconnect the sensor plug from the Rx8 first. I don't reccomend opening up the unit.
  Send a message via Yahoo to TekinTeamMgr
