stronger gerboxes or dd-outrunner in ax10 clone? -
05.24.2013, 05:13 AM
I mounted a 35x48 outrunner in the gerabox in my hsp pangolin (ax10 clone)
and after 2 min runtime onewheel got stuck an i bliped the trottle and CRUNCH" and the top two geras inside the cenrer gearbox stripped out :(
are there any bulitproof gearboxes that would fit ?
the center driveaxles are traxxasstyle telescope shafts made for 5mm output shafts.
i think that the most durable sulution would be a outrunner in direktdrive
i have a bigger motor 42x50 850kv ,with 5mm shaft would this bee enough ?
That Hot Racing gearset from rpphobby has a "52T" marked on it. That's the same number of teeth on a B4 2.6 trans and RC10GT 2.6 trans diff gear. Do you know if these gears will fit in those associated cars? Ever tried fitting gears from the Axial trans in Associated gearboxes?
