My bro has made the decision to go direct drive by using an outrunner. I convinced him to do ths because their is alot of advantages. Some are efficiency, less heat issues, alot more torque, great top end while using direct drive... I have narrowed it down to one motor that looks absolutely perfect-
http://www.hobbycity.com/hobbycity/s...idProduct=2099
You guys might not think that this will do but I know it'll work great. The 50-55 600kv is crazy powerful in my heavy 12lb warhead. I got to use it once then the revo drivelines caved in. I went back to stock dog bones. The tires he's using are warhead tires/rims and his diff ratio is 2.85. He also has new MIP CVD's in all the arms so that should add some good strength to the truck. He will be using revo center drivelines to hold up to the outrunners torque. Ill let you guys know when updates have been finished.
