One of my Bday gift got here and somewhat modded
lutach
lutach's Avatar
One of my Bday gift got here and somewhat modded - 09.24.2008, 12:00 PM
Just got my Mamba Monster today and did my little MOD. Nothing special, but I'll let you guys see what I did. I noticed that the phase plugs seems to be touching the heat sink, so it might get shorted unless the space is so small that my 30yr old eyes can't see. I removed a little of the plastic off the bottom of the case just bellow the fan connector. The connector is actually 1mm or so too tall and after I did it the PCB sits flat on the bottom of the case. I added some foam to the bottom just to eliminate any more movement. The top case had a problem and you can see I removed some plastic to allow the male plug to go in with no issues. I will run the ESC in my BPP with 5S and 6S powering a Neu 1521/1Y with 20T/65T gearing. I will also be running the old version of my 6S ESC Here are the pictures:
lutach
lutach's Avatar
09.24.2008, 12:01 PM
lutach
lutach's Avatar
09.24.2008, 12:02 PM
e-mikey
09.24.2008, 04:36 PM
Good luck with it man! Happy bday.
lutach
lutach's Avatar
09.24.2008, 04:58 PM
Thank you.
e-mike
e-mike's Avatar
09.24.2008, 05:09 PM
great gift to have for a bday..!!!!!!i hope that is a good unit
D8t on juice!!
emaxxnitro
emaxxnitro's Avatar
09.24.2008, 05:11 PM
those bullet plugs worried me to so i did the same( still went up in smoke though)
808E
lutach
lutach's Avatar
09.24.2008, 05:16 PM
I have a feeling this unit will do the same. They are just too close to the heat sink. From what I could make out, they seemed to be touching the heat sink. Maybe that's the problem with the Monsters and probably nobody at Castle saw it.
09.24.2008, 05:48 PM
Happy Birthday Luciano. Hope 30 treats you well, I am not far behind you (in age, not distance)!!!
lutach
lutach's Avatar
09.24.2008, 06:19 PM
Thanks linc pimp master. This is my year to shine with some RC goodies man. I just spoke with somebody and I'll soon be making a nice conversion for the great TC3. I also spoke with another person and soon I'll have my own motors too. I'll go slow as I don't want to stop putting money away for my daughter. She needs it the most you know. It should be awesome.
Happywing
09.24.2008, 05:54 PM
My MMM V2 has a bunch of mods, but I missed this one until a friend of mine pointed it out. It's been running good for a while, but I now see that two of the motor connectors are touching the heatsink. So far:
1. Case bottom mod
2. Case top mod
3. Remove fan
4. Disable BEC
5. Run Rx Lipo w/regulator
6. Change switch to MM switch (so it doesn't turn off mid-race)
7. Rx cable opening made bigger
8. Rx cable shrink wrapped
9. Connector/heatsink contact mod coming
High maintenance little controller!
lutach
lutach's Avatar
09.24.2008, 06:20 PM
1. Case bottom mod
2. Case top mod
3. Remove fan
4. Disable BEC
Let me know how your connector/heat sink contact mod goes. I almost got Dremel happy, but I don't want to mess things up.
Happywing
09.25.2008, 06:52 AM
So far, no luck. I can't get the connector off the board. The heatsink is in such good contact with the connector that I can't get it hot enough. the heatsink just sucks away the heat. I've about had it with this controller. Who's found a better alternative?
sikeston34m
sikeston34m's Avatar
09.24.2008, 06:05 PM
If Castle could insulate the outside of the power cups with some sort of shrink, it would help center the heat sink more precisely during the assembly process.
Your heat sink is hugging the cups on the motor side, where mine is hugging them on the power side.
lutach
lutach's Avatar
09.24.2008, 06:21 PM
They could 've used some sort of fiberglass insulation.
