MMM dead and its all my fault!!!
shizzon
shizzon's Avatar
MMM dead and its all my fault!!! - 02.28.2009, 02:48 PM
well im pretty sure my MMM has kicked the bucket and the blame is intirely on me. I got out the RCM 5s lipos for their 4th run and accidentally used my series connector that i use on my 2s packs for 4s. I didnt notice it at all and proceeded to drive the truck around on 10s or a minute or so, and it ran fine until it just died....I tried to get it going (i thought it might have been a loose deans or something) and then i saw the huge mistake i made when hooking up the packs.....
This sucks, Its totally my fault so i dont expect any warranty from castle, but i want to be able to drive my truck and didnt plan on spending $160 dollars on a speed control any time soon.
So does anyone know if theres any chance with castle to get a discount or something....i take all fault on this one but it would be awsome if they had some trade in program like traxxas does....
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
shizzon
shizzon's Avatar
02.28.2009, 03:01 PM
anyone know if castles Flat fee will take care of this and repair my esc for $70. if this is true it will save me some $ at least.
Toys:
Slash with VXL
sikeston34m
sikeston34m's Avatar
Is there any chance you could remove the bottom of the case and take a picture for me? I'm thinking it's probably blown the TVS chip which led to other problems. Probably took out the BEC circuit as well.
To answer your question, yes.
http://www.castlecreations.com/support.html
It looks like flat rate repairs is $70. They can fix you up.
Sorry about your luck with this one.
shizzon
shizzon's Avatar
02.28.2009, 03:02 PM
yeah I can do that, give me a bit.
Toys:
Slash with VXL
e-mike
e-mike's Avatar
02.28.2009, 03:36 PM
so if you said that you run it on 10s lipo for about 1 min....it seem that 7s or 8s coulb it be ok if we desactivate the esc bec......
like you said its suck,,,me two i blow up a mmm by reversing the neg,positive born.....
total cost..100$can
im curious the see inside you unit
D8t on juice!!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.28.2009, 03:56 PM
Castle's flat fee repair will cover this! They have said it doesn't matter how or why it died as long as they can identify what it once was! You can send in a charred piece of plastic and as long as they can tell what it was they will take care of you. $70 is still costly but 1/2 price of a new one.
shizzon
shizzon's Avatar
02.28.2009, 04:06 PM
Yeah, 70 bucks is better than 140! and it ran well for the 1 min that it was running, luckily i didnt give it any more that 1/4 throttle and probably maxxed out at 30 mph, so my motor should be fine, at least everything else is fine.
Toys:
Slash with VXL
shizzon
shizzon's Avatar
02.28.2009, 04:10 PM
to be honest im surprised that the controller let me drive it with over 37V going to it....i would think that it would give an over voltage warning and prevent it from running.
Toys:
Slash with VXL
02.28.2009, 04:11 PM
I'm surprised the power on 10s wasn't so huge that it threw a red flag! But yeah, the flat rate fee will cover it. Not cheap, but pretty darn good compared to a new ESC.
As to using anything higher than 6s; I wouldn't do it, even with the BEC disabled: 1) the BEC is never "disabled", removing the red wire simply keeps it from powering external components, but it still powers the brains. 2) The FETs and caps (and I'm sure a bunch of other components) are not rated for much beyond 6s. IIRC, the FETs are rated for 30v, and the caps are 35v. And you always want to leave a little voltage headroom.
e-mike
e-mike's Avatar
02.28.2009, 04:21 PM
Not cheap, but pretty darn good compared to a new ESC.right
not bad 70$ for a new unit
i was thinking it was higher than that...like the 120amps continusly...
D8t on juice!!
shizzon
shizzon's Avatar
02.28.2009, 04:20 PM
^^i just thought that packs were getting broken in, lol. but really i only got on the throttle once and is was maybe 1/4 throttle, which promptly but the truck on its lid when it was already moving 25-30mph, so probably more power, i just didnt get close to flooring it to see.
Toys:
Slash with VXL
shizzon
shizzon's Avatar
02.28.2009, 04:50 PM
pics,
my untrained eye cant see anything obvious, perhaps some of you may.
Toys:
Slash with VXL
sikeston34m
03.01.2009, 12:57 AM
Originally Posted by shizzon View Post
pics,
Your V2 Brain Board doesn't appear to have the TVS chip that was added in the V3. Notice how the V3 board is longer, and also has a small square chip at the edge beside the "223 D" coil? That is the TVS chip.
On the outside, nothing appears burned, but I have a feeling the problem is in the little round thing that's marked "223 D". This is the main BEC switching coil. It probably overloaded trying to carry your servos.
One thing to check is your switch. Make sure that the switch if making. You can test this with a continuity meter. If you have a meter handy, I would also plug the Monster in, and check the BEC voltage being sent to the receiver.
I'm sure you have a dead BEC.
emaxxnitro
emaxxnitro's Avatar
02.28.2009, 06:43 PM
dude thats a v2! just send it in for a v3 upgrade , and yes 70$ is the charge even if you decided to run it over with your 1/1 car.
this is a v3 ( notice the blue board )
808E
shizzon
shizzon's Avatar
02.28.2009, 06:53 PM
I know it was a V2 but i got the v3 case and most recent software, from what ive heard its pretty much a v3
Toys:
Slash with VXL
