i can't deside 5s or 6s?
gizzmo79
i can't deside 5s or 6s? - 09.28.2009, 06:34 PM
I have a self made truggy, it running with the mamba monster max and a lhener 1500kv motor, i'm about to get som new lipos but i cant deside if i'm getting 5s or 6s. i'm thinkink about the new hard case lipos from thuner power 5s (2s+3s) 4200mha 40c, with a total of 250usd or the hardcase 6s(3s+3s) 2600 30c mike is selling to a total of 250usd.
What do you guys think, who should i get?
Sorry the bad english i'm from Norway
nitrostarter
nitrostarter's Avatar
09.28.2009, 06:55 PM
6s!!!!! You can gear down if too fast!
N. Rustler conversion
09.28.2009, 06:56 PM
6s...
junkman
09.28.2009, 07:24 PM
6s for that kv, if you are playing with it, if you are racing it would probably be fast enough on 5s. You could always play around with the gearing.
marzac2
marzac2's Avatar
09.28.2009, 07:31 PM
I would say 5S if your planning on racing it. 6S would be way fast for a track.
And why 6S hardcase? Do you have to use hardcase? It will make your battery hotter than if it were soft cased. By about 10-20 degrees. If you can do so, I would forget about the hardcase and choose the JUST AS SAFE OR SAFER alternative. Hardcases are for sanctioning bodies like ROAR to use as a disguise for safer batteries. Not necessarily safer by any means. And you will save a lot of money with the soft case too.
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.28.2009, 11:03 PM
Get a 6s(or 5s)5500, 4200mah, or 3300mah Hyperion G3 pack, 4200mah/6s is $200 and a hair under performance to the 40C TP packs.
Here is a 3300mah/6s VX (35C) pack that RCM sells here.
http://www.rc-monster.com/proddetail...33006S]&cat=18
gizzmo79
09.29.2009, 01:14 PM
I whant the hard case bacause my soft case lipos keeps breaking.
About the temp, i'd never any isue with that.
Okey what is the safer alternative?
marzac2
marzac2's Avatar
09.29.2009, 02:57 PM
Why are your soft case Lipo's breaking? If they are failing due to sliding out of your battery tray or moving around too much during driving, Your battery tray is to blame and not your soft case Lipo's. This is usually the case because some battery trays are not designed properly and don't strap the pack down good enough.
I was saying that the "safer alternative" to hardcase Lipo's is soft case ones, because they are able to run cooler and damage can be seen before it gets out of control.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.29.2009, 03:00 PM
Go 6S, but you could easy run 4S on a track with that Setup if you wanted longer runtimes and good speeds...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
09.29.2009, 03:38 PM
I would stick with 5s, lighter and easier to package especially if you plan to go with the hardcase lipos. I would go with the hyperion g3 35c lipos if it was my setup, and money! Just make a good solid battery tray that covers the sides/ends of the lipo completely.
gizzmo79
09.29.2009, 04:58 PM
I have tried that, but in the last year i have damaged 4 soft case lipos, if i'm ending up with soft case lipos i'll think i make a bullet proof battery tray.
4S is not an option its no fun, tried that. Tried with 5S and that whas more fun, but i wonder how it wil be with 6s
What do you guys use to build your battery trays?
aqwut
aqwut's Avatar
09.29.2009, 05:21 PM
6S is definately more fun
I use 2"+ angle aluminum to make mine...
needforspeed
needforspeed's Avatar
09.29.2009, 05:20 PM
Go 6s for sure,Thats what i run even on the track.You will love the extra power
