Why didn't it die?
V0RT3X
Muggy love
V0RT3X's Avatar
Why didn't it die? - 11.22.2009, 09:06 AM
Was running and jumping down at the park today(grass). I hit a jump and landed badly and it did over 10 cartwheels on grass. Run down, flip it over - nothing. Guess the connectors unplugged. Open the lid, the connectors are together. Then I see the negative bullet on the MMM is unplugged (V2). With the bullet loose I tried to disconnect the battery and all of a sudden the neg. plug touched one of the motor bullets and a spark flew up.(no smoke) Then I started thinking where should I order my new MMM and if CC will replace my V2. I carefully unplug the batts and also the motor connections. Then, with even more care I plug the lipos back in(thought it would catch fire) and the lights come up. Plug everything back and it's working normal.
I was running 6S.
Here's what happened to the plugs that touched:
Now, shouldn't it be dead from the hit?
coolhandcountry
coolhandcountry's Avatar
11.22.2009, 09:19 AM
Maybe a little luck and good build quality.
Peace!
Country
Help support the
Rc-Monster
Buy here
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
11.22.2009, 10:12 AM
I ran a MMM V3 on 10S by mistake until it thermalled. I go get the truck to investigate and see the mistake I made. Plug two 5S in series. Other than the TVS that is probably blown, the ESC still runs like a champ. They are tough devices.
No brain, no headaches.
himalaya
himalaya's Avatar
11.23.2009, 03:51 AM
What battery pack were you running ?
....What a Blue Sky....
V0RT3X
Muggy love
V0RT3X's Avatar
11.23.2009, 11:10 AM
2x3S Flightmax 5000 25C. When I got home the voltage was around 3.7V per cell.
Funny thing is that my Accucel 6 died when I wanted to charge the second battery. (resets when it starts to charge)
kalbien
11.23.2009, 05:58 AM
well you very lucky and using either quite discharged or low C batteries... I did connected +- connector on 5s 3300 vx hyperions and same sized connector as you have there just dissapeared. No idea where, but I was like "WTF, laser?"
batteries survived just fine however :)
11.23.2009, 06:12 PM
Sheer luck, and hard-as-nails esc
