uh oh
chase
uh oh - 12.15.2009, 02:24 PM
so i went to remove my motor for maintenance yesterday and noticed i had a missing tooth on my pinion. another problem is when i went to remove it the set screw is stripped. ive tried prying it off butt im worried i might mess my motor up. anybody got tips?
FastXR
12.15.2009, 02:28 PM
Did you loctite the pinion grub screw? If you did you may have to heat it a bit to melt the loctite. Try a different size hex driver (ie metric or inch equivalent or a torx bit, sometimes you can force one of those into the hex on the grub screw). If its totally stipped and you still can't get it out, take a rotary tool (dremel, die grinder) with a cut off wheel an cut a slot in the set screw so you can remove it with a flat blade screw driver. Hope that helps.
chase
12.15.2009, 03:46 PM
my last cutting wheel broke last night so im gonna try an extractor
brushlessboy16
brushlessboy16's Avatar
12.15.2009, 04:02 PM
Cutting wheel is the best, just put a slot in the set screw
simplechamp
simplechamp's Avatar
12.15.2009, 04:15 PM
http://homerepair.about.com/od/inter..._extractor.htm
Brushless Moose
12.15.2009, 05:33 PM
or just slice the pinion down the middle parallel to the motor shaft and it will just fall right off
12.15.2009, 09:16 PM
I had to do this once before after everything else failed to work. Sacrificing a pinion is a lot cheaper than a $ 150- motor.
Urgeoner
Urgeoner's Avatar
12.15.2009, 11:12 PM
When my pinion got stuck like this with locktite, I just drilled it out...didnt harm the motor shaft a bit.
SV6000
SV6000's Avatar
12.16.2009, 08:32 AM
this happened to me as well. I just drilled out the set screw and than ran a tap through it to cut the thread again. Just be mind full not to go to far with the drill or you will start drilling into the motor shaft
CUBIC INCHES = CUBIC HORSEPOWER = CUBIC DOLLARS
