Center Differential Motor Mount Thread
brushlessboy16
brushlessboy16's Avatar
Center Differential Motor Mount Thread - 01.03.2010, 09:33 PM
They seem to be very popular. and if you want one- I might become your best friend... I have one that was installed on a buggy- but easily modified to fit on any other vehicle (Im actually using it on my savage). This design can fit up to a 51t spur gear without modification-aside from clearancing whatever plate it is mounted on.
I plan on mimicking this mount (after I get the approval from rc-monster mike). I will be using 1/4in 7075 aluminum stock and a cnc mill. By the final design expect to see more pockets for recessing and weight reduction. maybe even a unit to house larger spur gears... we will see.
Here is the mount that i have in my shop
Here are some of my original CAD design- updated one coming soon
Please post thoughts comments and concerns
JThiessen
JThiessen's Avatar
01.03.2010, 09:37 PM
Not bad. Let me know when you are ready to produce some - I might be able to use one for my LST conversion.
What center diff was it modeled for?
brushlessboy16
01.03.2010, 09:53 PM
My mount will be adjustable- for a range of diffs. the current one is setup for larger diffs like the savage(shown) and the ofna diffs. the new design will accomodate the smaller losi style diffs.
pinkpanda3310
pinkpanda3310's Avatar
01.03.2010, 10:57 PM
I love it How much clearance does it need underneath with a 51 spur ?
I'm in the process of making a backyard(ghetto) mount for my lst2 but of course it's not as swish as that.
brushlessboy16
01.03.2010, 11:10 PM
Originally Posted by ANGRY-ALIEN View Post
Very nice work man... I'm sure your designs will be well received by many of the members here... The FLM Maxx and Gorillamaxx guys are going to be watching this closely..
Keep up us updated
Alien
Will do- thank you for the compliment
probably about 2-3mm- i have a losi 50t on there now and it contacts the plate that its mounted on- needs about 1mm to rotate free
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
01.03.2010, 11:06 PM
Keep up us updated
Alien
Jabe
01.04.2010, 10:27 AM
That would be great for bashers, but for serious driving COG raises too much.
This is something that i would have needed for my Hyper ST Pro conversion.
JThiessen
JThiessen's Avatar
01.04.2010, 12:12 PM
I was thinking the same thing last night. BB - depending on what software program you are using, you might be able to paramaterize the motor mount portion (positioned sketch or something) to allow individuals to specify an angle to have the motor sit at..straight up like you have it would be zero degrees, rotated to the left would be a negative angle, to the right, a positive.
brushlessboy16
01.04.2010, 01:04 PM
If your worried about COG- get one of mikes standard mounts. this is not made to be low COG- I have raced a buggy with this mount- the car is much more balanced- kind of counteracted the higher COG..
if you want your motor on the side- get an rcm mount- I guess you could clock it... Now you have me thinking- I need to look into it now
whitrzac
Can't catch this...
whitrzac's Avatar
01.04.2010, 01:18 PM
make sure to make a recess in the top in order to get a hex into the pinion
brushlessboy16
01.04.2010, 01:24 PM
already have that. need to mill a portion in so that the shank of the pinion will slide in- I know Im having a tough time getting pinions to fit on my 2200(shortened shaft)
As for clocking the motor- your limited to about 30degrees each way- or i would need to make a custom top plate for 45 degree mounting.
My idea now is tho have the actually motor plate clockable- 10 degree increments or so.. but making a devoted 45 degree mount is more practical and would cut down on machining time and less waste material...
bruce750i
bruce750i's Avatar
01.04.2010, 06:41 PM
Most Diffs I would think, not just the slipperrent. diff.
Looks good on paper BB16, lets see a prototype with some hand porn before you get my 300 beans.
Just in.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Just in. - 01.04.2010, 06:46 PM
I just received a reply from MonsterMike about this very thing. I cannot believe you sold yours Harold.
These will be in the store VERY soon, Jerry. I have been busy with maintaining current items during the holiday rush, along with trying to get some family time in, but these are on "the list". These are a little bit of a pain to make, along with being a specialty item in many ways, so I have to work them in between the "bread and butter" stuff. I think there are enough folks waiting to justify the production of them - just need to work them into production. I hate to make any more empty promises for a timeline, but I am going to TRY to finish 20 or 30 of these this week. :)
Happy New Year!
Monster
SUPERMAXX YOUR LIFE.
ASYSTEMERROR
01.04.2010, 07:02 PM
I ask because this turns your savage into a 13lbs. "Truggy" this would be cool with 8s setup.
brushlessboy16
01.04.2010, 10:38 PM
What setup are you running in the savage?
MMM and Rx8 should handle direct drive fine- dont think it makes a huge difference... Working on the updated cad model now
