Been out of the game for a while.
B005T3D Fox
Been out of the game for a while. - 04.18.2010, 05:34 PM
So today i decided to pull out my hyper 8 out of hibernation. Just to discover that all three diffs were destoryed. Should I go with OEM or somthing else. I'm running 4s so I'm not making that much power. I just need some help on what to pick.
04.18.2010, 09:02 PM
Are the stock diffs that weak? Even on 4s if they are not shimmed correctly, they will not last long. I blew 2 diffs on my mbx-5T due to my own stupidity of improper shimming
check to see if these might fit...http://www3.towerhobbies.com/cgi-bin...?&I=LXLGV5&P=Z They may be stronger than the stock ones
B005T3D Fox
04.20.2010, 09:35 AM
The diffs i had in it were abused from the get-go. lol First nitro then the convesion the have taken a beating.I counted the teeth last night out of my center diff and the numbers are, 20 for the big spiders and 10 for the small spiders. The ones you linked are the same. so they should fit right??
simplechamp
simplechamp's Avatar
04.20.2010, 12:46 PM
I would think so. I have a few sets of those I plan on trying out myself. Should be a big upgrade from the cast alloy ones in most stock diffs.
B005T3D Fox
04.21.2010, 09:32 AM
Another reason why I think they worn out was they were not shimed right. I really dont know how to accually shim them. Can someone explain how to shim a diff right.
George16
Supermaxx
George16's Avatar
04.21.2010, 09:36 AM
Those will fit. I have them in my Hyper 7 diff case on my supermaxx and inside the Kyosho diff case for my ST RR. Hyper 7/8/8.5 share the same diffs by the way.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
04.21.2010, 10:10 AM
different diffs, but same concept. how to shim diffs.
Eflite Blade 400 heli on 3s
B005T3D Fox
04.21.2010, 05:48 PM
I think i will go ahead and also buy a shim kit (if available) and 2 new sets of pinions and ring gears just to make sure its all new. When I opened one of the diffs there were no shims! lol either I lost them one day when doing a repair or somthing. This might have also added to the headache.
