9L on 16 cells
rcjmaxx
9L on 16 cells - 12.31.2004, 10:22 PM
I have the Feigao 9L with the 9918 controller that I run with 14 cells.But I see in your add that the 9L can be run up to 16 cells,is this really safe for this motor?What can I expect performancewise and with what gearing is advised?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
12.31.2004, 11:20 PM
The 9L can take 15-16 cells. It is working pretty hard at that voltage, though. The power will be pretty insane on 16 cells. if you are running 14 cells now, gear down a tooth or so when you go up to 16 cells and you should be pretty safe. Just get ready for some torque!
rcjmaxx
01.01.2005, 12:16 PM
When you say "gear down" you mean more teeth on the pinion gear? I currently run 16 so go to 18 or so?
MaxxFusion
MaxxFusion's Avatar
01.01.2005, 03:00 PM
Gear Down = Less Teeth
  Send a message via MSN to MaxxFusion
RC-Monster Mike
Site Owner
01.02.2005, 09:58 PM
Right. Gear down means less teeth on the pinion or more teeth on the spur. The pinion is easier to change, so that is the best way to adjust your ratio.
coolhandcountry
coolhandcountry's Avatar
07.20.2005, 08:47 PM
Hey maxx how does that 9l do on 16 cells?
Peace!
Country
Help support the
Rc-Monster
Buy here
