Looks like Lipo really is the future according to Novak
crazyjr
crazyjr's Avatar
Looks like Lipo really is the future according to Novak - 06.19.2007, 02:06 PM
I found this this morning, http://forums.radiocontrolzone.com/s...d.php?t=239086, has cut off for 2s and 4s lipo, depending on how you wire it
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
06.19.2007, 02:34 PM
hmmm... funny, i've been thinking of using my 6.5 esc with my lehner to see how that combo works together. :005: my hv system is just laying around as a spare system - i may have to solder the 2 together and see how it works.
nice that the new esc comes with the lipo cutoff.
Eflite Blade 400 heli on 3s
crazyjr
crazyjr's Avatar
06.19.2007, 03:51 PM
won't work, the novak is sensored the lehner is sensorless
Serum
Serum's Avatar
06.19.2007, 04:13 PM
Is it me or is it just the old hvmaxx controller with an external fan and an external LVC included? (novak 5471)
http://www2.towerhobbies.com/cgi-bin...?&I=LXPGN1&P=7
ClodMaxx
ClodMaxx's Avatar
06.19.2007, 04:14 PM
i thought i've read before that sensored systems can run a sensorless motor - just not the other way around.... ?
Serum
Serum's Avatar
06.19.2007, 04:22 PM
other way around. a sensor based motor can be used on a sensorless controller, since you are not using the sensor wires. A sensor based controller doesn't use the EMF to determine where the n/s poles of the rotor is located, it uses a HALL sensor.
ClodMaxx
ClodMaxx's Avatar
06.19.2007, 04:23 PM
ahhhh, ok. thanks guys.
sven
sven's Avatar
06.19.2007, 05:13 PM
Just for clarification, a Novak SS motor could be used with a Mamba Max ESC?
I am curious about this because I have a Novak motor that I would like to use, but the ESC does not work. And I would like to try the motor with my MM.
Does anyone have any experience with this, or is it just a common knowledge thing?
crazyjr
crazyjr's Avatar
06.19.2007, 06:46 PM
thanks, I didn't see that the cutoff was seperate
crazyjr
crazyjr's Avatar
06.19.2007, 06:52 PM
the only esc's i can recall being able to do that with each in their element is the traxxas velineon and the GM brushless esc, but not sure on the GM one
skellyo
skellyo's Avatar
06.19.2007, 07:37 PM
You can run it, but it's possible that you'll have problems with cogging on it. For some reason, most Novaks are not real happy on MM ESC's from what I've read. However, there is a very long thread on rctech.net where a guy has been using a Novak 4.5R motor on a MM ESC for a while now with mixed results. It certainly won't hurt to try it. If you try and it doesn't work well, before you give up, be sure you exhaust all the options in programming as far as start power/timing/punch control.
06.19.2007, 08:07 PM
Are the Novak motors built the same way as the Neu's? Are the symptoms similar?
sven
sven's Avatar
06.19.2007, 08:10 PM
Thanks for the info, I will check out that thread and give it a shot.
NovakTwo
Senior Strategist
06.19.2007, 09:04 PM
Sven, you could return your old Novak esc and exchange it for an XBR (rmf) for $49.00.
service replacement options
Novak Electronics, Inc.
skellyo
skellyo's Avatar
06.19.2007, 09:37 PM
Here's the thread I was talking about:
http://www.rctech.net/forum/showthre...&page=43&pp=30
