aad
08.15.2005, 05:14 AM
the tranny is in the normal position it's just the motors that are now in the rear on top of the esc location and the pinion faces the front instead of the normal where in it the pinion faces the rear of the truck when i tried to install the titan motors to test it out it ran backwards now i don't know if i should reverse the installation of the diffs internal or just flip the whole casing what will happen to the pegs of the the diff casing that attaches to the bulkhead i don't think that if i flip it it would fit into the slot or will it?
Dafni
Dafni's Avatar
08.15.2005, 05:24 AM
Just flip the whole cases. The pegs that go into the bulkheads sit on this ring, right? Just turn the ring 180°, and it fits right in.
coolhandcountry
coolhandcountry's Avatar
08.15.2005, 09:06 AM
When you take it down. you will see what dafni is talking about.
aad
08.15.2005, 09:44 AM
thanks guys I'll probably work on it over the weekend and will test it out
I also used the extended chasis of the gorilla maxx is there an mip cvd that would fit in it I already ordered the cvd's for the four corners do you think i need the middle drive shafts changed to cvds also
coolhandcountry
08.15.2005, 10:02 AM
The plastic should hold for little while. At high speed they seem to melt more than anything.
crazyjr
crazyjr's Avatar
08.15.2005, 10:52 AM
Yes as everybody said just flip the whole case. very nice truck BTW.
