83gt
01.21.2008, 03:31 PM
I would like to see some of those UH hybrid outrunners in action. I tried both align 600l and xl on 5s and they worked well for me in my old emaxx. They are around 1600kv and work well with a quark controller.
I might just give it a shot. Heck, for $39, i'm not losing much if it doesn't work very well.
01.21.2008, 05:21 PM
If it has anywhere near the performance of the align motor you will be happy. The spool up was slightly slower than an inrunner, but so much more torque. Very smooth power delivery as well. And it did not get hot at all. Hope the UH hybrids are as good as the align.
sikeston34m
sikeston34m's Avatar
01.21.2008, 06:38 PM
The crazy thing about that motor is its based on a 5mm shaft and its turned down to 3mm where the pinion goes on it. I think they were aligning it to work with stock emaxx pinions.
I think like most outrunners its just a matter of losening a set screw that holds the shaft in place and replacing it with a 5mm shaft that isnt turned down on the pinion end. Should be easy to do if you can find a 5mm piece of rod and cut it to length. I could be wrong on that, but I think that is the case on most Outrunners.
Hey Jhautz,
You just described exactly what I did to the very motor I got from you. LOL
Desmo
01.21.2008, 06:46 PM
how about this?
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=020
Does the shaft come out in all out runners? This cheep ebay one also looks like it has a bushing for the shaft on the mount side, is this normal?
sikeston34m
01.21.2008, 06:57 PM
Originally Posted by Desmo View Post
how about this?
I have found a few that the shaft doesn't come out of, such as certain models of the Century Brand Outrunners. It's a press fit PITA.
That's not a bushing that you're seeing, it's a spacer. This motor does have bearings. I've never found an outrunner that didn't have bearings.
They chose to go with a spacer and a snap ring instead of a lock ring collar.
johnrobholmes
johnrobholmes's Avatar
01.21.2008, 09:02 PM
The ebay emax motor is 180gm. Pay attention to the weight. 225gm or higher for an Emaxx.
Desmo
01.21.2008, 11:29 PM
not to hijack this tread but if the numbers are the same why is the weight not the same or close?
jhautz
jhautz's Avatar
01.21.2008, 11:58 PM
Hey Jhautz,
I cant tell you how many times in the last year I wished I didnt sell that thing.
Gimmie it back
lol
to make it...
or break it...
Silent...But Deadly
jhautz
jhautz's Avatar
01.22.2008, 12:04 AM
That may change by the end of today. Check for an update in 4-6 hours (if all goes well).
I didnt see anything in the revision history on the CC site.... What do you know? Is the fabled MM fix finally about to be released?
to make it...
or break it...
Silent...But Deadly
johnrobholmes
01.22.2008, 01:52 AM
They got the C link done, the webmaster should upload it onto the site tomorrow.
johnrobholmes
01.22.2008, 01:56 AM
Because sometimes a manufacturer will stretch the truth a bit. I have found the easiest way to rate an outrunner is with weight. Same for batteries. If the motor is too small, it will have to work a lot harder. If the motor is too small, it will also have trouble dissipating heat. I have that emax motor you linked to. It is about 6.5 ounces and not really all that powerful (for a revo). The air gap and stator laminations are huge too, so it isn't very efficient.
It would work, but you will either have so-so performance or the motor will burn up in short order.
Desmo
01.22.2008, 02:04 AM
Cool, thanks for the info
