Duster_360
02.04.2008, 08:16 AM
I'm going to try to set mine up tonight and I'll see if it writes CDR type files. If this is bug, at least its not a bad one to fix.
Finnster
KillaHurtz
Finnster's Avatar
02.04.2008, 03:04 PM
Hmm, I just updated mine and it was doing the same thing. I was trying to open Art1k's ET data he attached to a thread in the BL section and it was displaying 0's for me....
02.04.2008, 04:16 PM
Did you try plotting the file?
Duster_360
02.04.2008, 05:25 PM
I'm setting mine up. At a panel labeled "Choose the Type of Models". There is a note on this panel that reads "If you have the MicroPower eLogger, choose the Flight option".
Just taking the logical option, you would choose Model Cars, trucks of other ground based vehicles if you didn't catch this note. Model Cars apparently is not the right option. This panel also says you can change this later by going to "Tools, Choose Model Type".
Finnster
KillaHurtz
Finnster's Avatar
02.04.2008, 05:28 PM
If I switched to the graph mode it just displayed flat lines. The file is fairly big, and the timeline is a specific 18.XX mins, so i'm guessing its the same probs listed above. I'll try some of the tricks above to get it to work.
