Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Hyperion Charger
drivelosi
Hyperion Charger - 02.18.2008, 07:52 PM
I just bought 2 max amps 6s 5000mah lipo packs and now need to purchase a charger that will charge a 6s pack and was wondering if anyone had used a hyperion eos 1210i charger and balancer. And is so does it work well and is it user friendly. Thanks
DickyT
02.18.2008, 08:15 PM
hyperion chargers are some of the best lipo chargers available. I have no experience with an eos 1210i, but have used an eos5i and eos 0606i. I just ordered an eos 0610i for myself.
They are very user friendly.
drivelosi
02.18.2008, 09:10 PM
I will probly never go more than a 6s lipo so would the 0606i be a better choice for me and just add the new maxamps method balancer?
david lamontagn
02.18.2008, 10:12 PM
I've the Hyperion 0610i and it's the best charger that i've never have, it's awesome!!
But if i have see this one first, i had take it for sure, it's the 0610i Duo!
http://media.hyperion.hk/dn/eos/EOS0610iDUO-MAN-EN.pdf
Maciolus
02.19.2008, 12:48 AM
I have Hyperion 0610i. If you need no more than 6S this is perfect charger for you.
Pros:
+ A123
+ PC compatibile
+ integrated balancer
+ 250W
+ network connection of 2 of these if you need >6S
Cons:
- no discharge function (with current firmware)
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
gixxer
gixxer's Avatar
02.19.2008, 01:19 AM
the 606i is limited to 50watts. you are going to want either the 1210i or 610i.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Countryhick
02.19.2008, 03:19 AM
+1
Countryhick
02.19.2008, 03:48 AM
+1 You will find due to the low output of the 0606i (50 Watts) you will only be able to charge a 6s pack at a max. of 2 amps = slow.
If you go for the 1210i (max. output 180W or 7.1 amps @ 6s) or the 0610i (max. output 250 W or 9.9 amps @ 6s) = fast charge.
I have the 0610i and luv it!!!
Check out this page HERE and have a go at Brians charger calculator.
Hope that helps
Cheers Andrew
P.S. Just be aware that you will need a good power supply to feed the later 2 chargers. Brian has also added a power supply calculator to the page I have linked be sure to check it out as well.
neweuser
neweuser's Avatar
02.19.2008, 01:24 PM
I do not personally own it, but it is nice and most Hyperion chargers are user friendly. I own EOS7i and the MRC 989, I happen to love my 989 as my EOS7i had issues charging my 5s. The 989 does it with out a glitch, and it comes with a powersupply!
