jzemaxx
03.16.2008, 11:51 AM
Do the stock GST tires balloon bad at high speeds? I just bought an XTM MMT and am doing the same thing you are with it and the MMT is even bigger then the GST. I know feeling the stock tires that they are going to balloon bad. Let me know what you find out, cause other then myself and you I haven't found anyone that has these big trucks running brushless.
I'm going with a 1521 1.5D and HV110. I'm looking for 70mph on 10S.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.16.2008, 12:19 PM
They're pretty low profile tires, they do balloon... but I haven't noticed really bad ballooning...
think that motor is going to push the GST to 70MPH... Conversion will be about 17-18Lbs...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
jzemaxx
03.16.2008, 12:31 PM
Mine weighs 18.5 lbs and talking to Steve at Neu he says with 37V's their should be no problems reaching 70+mph. He said aerodynamics is going to be the main problem with a truck this large. Getting it low and stable is the key. I bought the Trinity heavy springs to tighten the suspension up and it will also lower the truck about 1 inch or so.
Also I went with the Neu cause of the 4 pole motor which has more torque.
Hardstyle
Hardstyle's Avatar
03.16.2008, 12:51 PM
A guy from germany has done a belt driven nemesis, it was pretty cool. Cant find the pictures anymore. But heres the video http://www.myvideo.de/watch/940850
othello
HV basher
03.16.2008, 04:03 PM
The pics of his built are gone. But this is what he wrote about his truck.
Motor: lehner 2230/16 with a Reisenauer Gear reduction 6:1
Controller: Schulze 40/160
Batts: 24 x GP 3700 Nimhs
Geared for 34 mph. 24 minutes driving per charge. very low temps of every component.
He made a custom mount for it to be belt driven. That's all i remember.
But i guess a belt would't hold up the power aqwut is lookin for.
lutach
lutach's Avatar
03.16.2008, 05:14 PM
I hope he doesn't get angry at me .
ID:	4232   Click image for larger version
othello
HV basher
03.16.2008, 05:46 PM
Seems as if your hard disk is well organized when it comes to rc. Those were exactly the pics i was looking for.
lutach
lutach's Avatar
03.16.2008, 06:51 PM
I liked the way he set everything up and I was going to make something similar with the belt drive system.
Takedown
WARNING: May become violent.
Takedown's Avatar
03.16.2008, 06:54 PM
Wow that belt drive setup looks factory! Now the only issues is he needs to go lipo.
03.16.2008, 08:00 PM
Yeah, I think he built that truck before lipo was invented/mainstream & easilt available.
Seems like it would work in a Savage too, or any TVP type truck (I need to buy another TXT-1, oh how I miss the old girl....).
othello
HV basher
03.16.2008, 08:13 PM
If i remember it correctly he comes from hi speed boating (Saw events) and at this time Nimhs were prefered for hi Amp draws (lipos weren't allowed i think). Wheight isn't always a bad thing especially when it comes to handling on a rough surface.
aqwut
aqwut's Avatar
03.17.2008, 02:36 AM
yeah, that GST build was nice.. I saved the pictures too.... I like the belt system, I thought of doing the same thing, but I'd have to use double kevlar belts..
JzeMaxx.. what's that 1521 motor capable of ?.. 2500 Watts?..
I still don't thing that will bring you to 70MPH...
JohnnyMax.. had 2700 Watts on a maxx truck and just made it over 70MPH.... now, mayb that 1527 might be able to do the job...
lutach
lutach's Avatar
03.17.2008, 07:48 AM
My 1521/1Y on 10S gave me a little taste of 4670 Watts and a blown rear diff.
03.17.2008, 09:26 AM
Hey Aqwut, why not go with the dual 1527's and a dual-belt system? If I refer to the gear on the center differential or whatever it drives as the spur gear, and the gear on the motor shaft as the pinion gear, then why not have a very similar layout, except with places to mount two motors, instead of one, like the E-maxx motorplate, and have one "pinion" be farther out than the other by mounting the second motor farther forward by the width of one belt to avoid the belts hitting. Then have dual "spurs" (one right in front of the other,) hook up some belts, and you're ready to go. I hope this will give you an idea or two.
jzemaxx
03.17.2008, 09:45 AM
The 1521 will give you around 4000-4500 watts....and can run continous hovering around 3000 or so. Underrated for sure....
I have a 1527 1D, awesome motor as well, but they draw insane amount of amps....I don't like that with a light vehicle, and much less with a close to 20lbs vehicle.
