4s vs 5s =runtime
gimpygolden
gimpygolden's Avatar
4s vs 5s =runtime - 04.07.2008, 09:28 PM
I'm looking to buy another pack to use on my buggy and my 1/8 onroad.
I can run either 4 or 5s on both cars,which would yield the longest runtime if they are the same (3700)mah?
I know there would be a significant difference in speed but I am not concerned about this.
Would one run cooler than the other, all other things being equal? ie.gearing,motor
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
83gt
04.07.2008, 11:29 PM
If you don't care about the speed, there's no reason to go with a 5s. That is, unless you would like to switch to a lower KV motor. Difference in temps/runtimes will be negligible.
jhautz
jhautz's Avatar
04.07.2008, 11:36 PM
If you change the gearing to get the same top speed with either btteriesthe 5s will likely give you a longer run time.
18.5v * 3700mah = 68450
14.8v * 3700mah = 54760
More potential energy in the 5s pack.
The higher rpm the motor will turn will likly negate some of the extra energy, but by gearing it down to get the same top speed you should get at least some runtime advantage.
to make it...
or break it...
Silent...But Deadly
gimpygolden
04.08.2008, 10:05 AM
thanks guy's, I also just realized 4s would be the way to since I run mambamax on my buggy.
