Cain
05.16.2008, 09:49 AM
Hey guys.
I am currently looking to pick up a medusa motor to run on 4 cell lipo setup to be legal for the RC Pro Series in a newer style E-maxx which has already got the single motor setup, etc on it.
Anyway, I am wanting something that has similar KV to my Neu 1512 2.5D, and I am looking at the 36-60 V2 2000Kv motor.
Here are my questions, I hope you all are able to answer:
1. What kind of range of pinion gears do I need to use for this kind of setup to go a max of about 40 mph (looking at race speed here)? (14.8V, 2000kv) ( I am having trouble getting the gearing XLS to open up for some reason)
2. Do the medusa motors come with a flat spot already on the shaft?
3. Should I go with the heatsink version, or, the smooth can setup?
4. How much do the heatsinks interfer with gearing on the newer Emaxx, as well as say a 1/8 scale buggy?
5. Can you use the heat sinks as a clip ons (order them not bonded, just clip on as needed?
I think that is about it. Thanks again everyone!
05.16.2008, 11:14 AM
1. 24/58, though I'd suggest picking up all the available spurs for the emaxx 3905 & jato3.3 to experiment with.
2. Nope.
3. Smooth, dont really need a heatsink, only makes gearing adjutment harder due to larger diameter motor.
4. See above. Reported temps with even the 3300kv 50mm medusas are great in a 3905.
5. Nope- they are bonded to the motor at the factory, not a loose item you can order seperately. Best to use some cheap clip-on heatsinks & thermal grease to get the maximum heat transfer if you decide you need/want some heatsinks later on.
Cain
05.16.2008, 12:18 PM
so what does everyone recommend for a motor for the 3905 from the medusa line?
kostaktinos_mt
05.16.2008, 12:59 PM
if my opinion is welcome...
first, medusa heatsinks can be bought seperately:
http://www.medusaproducts.com/accessories/heatsinks.htm
the 36mm ones are usable with 36mm motors [apparently].
second thing to notice, the traxxas heatsink has smaller fins, and thus it`s a lot easier to mount and use than the medusa one. all other dimensions are equal between those two however.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJD62&P=7
i have been using those for years without any issues/interference...
the 36-60-2000v2 is a killer motor at 5s. a tad on the slow/conservative side at 4s however [it will need gearing up quite a bit]... so suicideneil got it right on with the 24/58 gearing: it should get you to 40mph approximately [with 4s and assuming 'close-to-stock' wheels/tires]...
  Send a message via MSN to kostaktinos_mt
Cain
05.16.2008, 03:02 PM
didn't know there were even more spurs. Will have to look into this more.
Too bad there isn't more mod1 spurs that fit the tranny as I have a good selection of mod1 pinions I would like to use.
gogglespaesano
gogglespaesano's Avatar
05.18.2008, 03:02 PM
would a 36-60-2000 v2 work an e-aftershock running 5s2p A123 and a MMM? on another forum some people were thinking that even though the can is the same size as a feiago L, with the 4 pole design it should have as much torque as a XL can.
what do you guys think?
tom255
tom255's Avatar
05.18.2008, 03:47 PM
BTW medUSA takes preorders on MR-036-060-2000V2-5 and lower KV motors, expected stock may 31
Buzzsaw46
05.18.2008, 05:16 PM
I almost ordered one last night, might still get a preorder in but I need to think on it. Kinda been thinking about an E-revo so another motor is needed but I might just go with a 75mm this time, the Tekno/Neu 1515 looks pretty nice.
05.18.2008, 05:22 PM
You can easily mod the mgt mod 1 spurs to fit the revo spec slipper assy.
WE NEED A STICKY ABOUT THIS!!!!!
Mainly as i am sick of typing this info!!!!
jfruge
05.18.2008, 10:22 PM
Here is my current setup. I need to work on an antenna mount for it. I have the 36-50 2000kv with 12/46 gearing. I just took a few passes today on the street. What are some steps I can take to keep the ESC cooler other than a fan on 4S ? it was about 95F here today and after my short run the motor was about 105F and the ESC 125F.
ID:	4627   Click image for larger version
John Fruge
Madera, CA
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , NEU 1512/3d, JR Z8800T
8ight pro buggy, RCPD Ultimate, 4s TP 5000, MM ESC , Medusa V2 36x50mm, JR Z8800T
05.18.2008, 10:30 PM
What are your esc settings? You could up the timing and see if that helps? From what I can gather the higher pole count motors prefer more timing. You could also turn down the punch control.
Maybe open some cooling holes in the body, and add a fan.
Buzzsaw46
05.18.2008, 10:32 PM
Nice buggy John. Do you have any airflow through your body? I used a toilet paper core to make a duct from the windshield to my motor and it did help, dont know if it was any better than just a hole though;)
05.18.2008, 10:37 PM
That is actually a really good idea. A duct like that could really flow, especially at speed. I may give this a try, sounds good for esc cooling. Maybe make a duct tube that runs front to back, and cut out a portion so that the esc heatsink can sit in the airflow.
jfruge
05.18.2008, 10:59 PM
I just re checked the settings and found that I was running the old SW.. v.09 and now its updated to v.17 I think I will leave things set the way they are for now and see if that helped.
Rev... off....
braking at 50%
Punch control 50%
Timming normal
LVC 12.4
Also I was not running a body for the road test / shakedown.
John Fruge
Madera, CA
05.18.2008, 11:31 PM
I have a feeling the new firmware will help...
