slimthelineman
slimthelineman's Avatar
08.31.2008, 01:16 PM
lol join the club, hes a busy guy though so i can understand
RBMike
RBMike's Avatar
08.31.2008, 07:25 PM
Mine died today. The fan controller died last week after about 1 hour of run time. I decided to get another before I sent his one back so I put in a fan running off the rx but today the car went about 2 laps & shut off. No bec voltage. V2 #1 for me after 2 V1's.
5S,Neu1512/3df,RC8,17/46
slimthelineman
08.31.2008, 09:56 PM
were you running an external bec when it quit?
RBMike
RBMike's Avatar
09.01.2008, 11:13 AM
No, I refuse to run an external bec when I paid for the one in the ESC to work. It's bad enough that we have to deal with the BS mechanical design on the fan and it's wire/ connector issues. I'm not running a crazy set-up or putting an unusual load on the anything. I'm running an Hitek 985MG steering servo and as Spectrum 3100 rx.
slimthelineman
09.01.2008, 11:28 AM
yeah i feel the same right now the outlook is not so good how many versions should we have to go through to get on that works. im on my second v2 and when i get both back i might just return them and wait..... again....
cheesecake
09.01.2008, 11:48 AM
mine should be here tomorrow now im worried about even trying it.
tc3_racer_001
tc3_racer_001's Avatar
09.01.2008, 05:11 PM
did you know they are now installing foam under the board... guess they must be listening :)
opened it up and was suprised how small it is, to fit all that stuff in the little board then make a gigantic case for it all. took off the bottom sticker so i can actually stick it to my mount, seems dumb to stick it on the bottom but o well.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
e-mike
e-mike's Avatar
09.01.2008, 05:23 PM
right for the foam..... i remove this foam after my second failure(my esc failed once and restart after power on)my esc failed second time and i open the case....i was tinking that the foam was my problem(maybe causing heat of the bec whatever.....)but...my v2 failed third time after 3 min....nothing to do...simply died
D8t on juice!!
