wich is the better lipo
lind5
Talking wich is the better lipo - 09.12.2008, 04:55 PM
hi guys well im full of questions today and this one is about liops
can you tell me wich lipos are better out of truerc and zippy r
im lookng at the truerc 4s 5000 mah 15c i think
and the
zippy r 4s 4150 mah 20 c
i have read some where on here i think. that castle creations dont think that true rc lipos are that good for there mamba monsters
dont no how true this is and thats why im asking
has any one done any real testing
i have been told to try get a higher c rating that i can
but as like maxamps that are really over rated are the above make of lipos
true to the ratings
09.12.2008, 05:13 PM
For what vehicle/ESC/Motor? both of these are only good for about 80amps...
Takedown
WARNING: May become violent.
Takedown's Avatar
09.13.2008, 12:47 AM
If were you I would go with the TRC pack. They do exceptionally well over zippy's.
RIP- Tammy (9/14/08)
JeffEmbracedDC
JeffEmbracedDC's Avatar
09.13.2008, 01:39 AM
Totally depends on what kind of car you're using, gearing and the motor you use.
Fill in those blanks and we can definitely help out.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
tc3_racer_001
tc3_racer_001's Avatar
09.13.2008, 07:43 AM
used my 4800 zippy today and WOW. never had this power on nimh. cant imagine what an even more powerful pack could do! im considering a smaller pack too... any suggestions? (lighter - see sig)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
spaz163
Functionality with a dash of Form
spaz163's Avatar
09.13.2008, 10:18 AM
I know exactly what you are saying TC3, I ran my Ofna MBX conversion off 14 cells NiMh for quite some time and now that I have my 4s Zippy-R 4800 it is pretty much a different animal.
But as far as which batts are better. I went through this too before I bought the zippy the only thing that convinced me to go with the zippy is the numbers. Well and the Eagle tree data that Finnster supplied earlier.
And check this out... they have them in stock and you know you can't beat that price. http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack You can pick me up one for the suggestion.
lind5
09.13.2008, 03:16 PM
-Jeff
well mate its in a converted lst2 with a emaxx gearbox
using
1515 1.5d 2700 kv might change when i can afford it
mamba monster
spur 54 t mgt steel mod1
pinions hardend 16/17/18/19/20
proline 40 series wheels
proline mulcher tyres
was going to go 6s but been told to stick to 4s with this motor
BL-Power
BL-Power's Avatar
09.13.2008, 03:21 PM
I would take the Zippy, i've got Zippy packs in all my cars and trucks and they are all working great and take much more than the spec says.
 Send a message via ICQ to BL-Power
spaz163
spaz163's Avatar
09.13.2008, 03:45 PM
using
mamba monster
2700kv is quite hot for that large truck, probably will pull some serious current!! You will need some lipos that can keep up!
phatmonk
RC carbon junkie
phatmonk's Avatar
09.13.2008, 03:54 PM
I would order one of these but dont they have a odd balancing wire harness.And if so where can I get a balance wire harnees that works.Now all I have are the Maxamps lipo batteries.
spaz163
spaz163's Avatar
09.13.2008, 03:58 PM
The balancer plug on the Zippys are what they refer to as JST-XH plugs... which are exactly the same as align plugs. I just recieved an align extension for my zippy lipos and it fits perfect.
tc3_racer_001
09.13.2008, 06:33 PM
they are the most common plugs - all chinese packs use them. they are not hyperion or TP or any of the name branded ones (apart from align)
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
JeffEmbracedDC
09.13.2008, 06:44 PM
using
mamba monster
Definitely a hot motor for that truck. Honestly, the only way you'll get it to work reliably with that motor is on 4s and you'll have to double up your packs in parallel which will double your maximum discharge rate.
Ideally you'd replace that motor with something closer to 1500kv run on 6s. But if you were stuck with that motor I suggest you run two 4s 5000mah 20-30c Zippy packs in Parallel ending up with a 4s2p configurating and 10,000mah. That would be about 250a you could pull from those batteries and honestly at that point you might have issues with your ESC. That's a lot of amps!
If you only used one battery it would be about 125a max and honestly you'd end up with bad performance and puffed lipo cells.
Your best bet by far is to get a 1515 or 1521 around 1500kv and go with 6s lipo.
I personally run Zippy packs and have had no issues.
-Jeff
tc3_racer_001
09.13.2008, 06:46 PM
and end up heavier than ever! but i agree its the only way it will work.
ryan
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
JeffEmbracedDC
09.13.2008, 06:54 PM
ryan
Super heavy, yeah. Those batteries are over 1.5lb each.
