RC8 Buggy Build
Fast5sRevo88
RC8 Buggy Build - 09.25.2008, 07:15 PM
I'm about to start a RC8 buggy build and need some ideas for batteries. I know i want to use Flightpowers and the must fit in a RCPD mudguard/battery tray (i already ordered it). I want to go hv and have has many mah as possible without lifting the body any. Can ya'll please post some flightpowers that will work? But if 4s is all that will fit properly, post that also.
brushlessboy16
brushlessboy16's Avatar
09.25.2008, 07:18 PM
what are the dimensions of the tray?
Fast5sRevo88
09.25.2008, 08:13 PM
The dimensions are 48.5mm wide x 170mm long. Micke_b on the forum has a RC8 on 6s Maxamps 4000mah with this tray, the height of his packs r 38mm.
cheesecake
09.26.2008, 01:21 AM
i use the zippy lipos there a bit wide but if you shave the tray a bit they fir just fine. i run a 5s setup
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
09.26.2008, 02:37 AM
These may be a bit tall, but here ya go...
http://www.hobbycity.com/hobbycity/s...00mAh_25C_5S1P
http://www.hobbycity.com/hobbycity/s...00mAh_25C_6S1P
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
Fast5sRevo88
09.26.2008, 03:01 PM
I saw your buggy build that u used mike's tray, are u still use it. Thanks for the info, but i will be using the RCPD one which is about the same dimension as mikes, but i don't know if it is as easy to shave down as mike's.
09.26.2008, 03:07 PM
If you want HV, try the Impulse lipos. I have a 3s 3200mah pack and it's lower profile than a 6c pack.
http://www.hobbypeople.net/gallery/182373.asp
I'm assuming you want 8s? Higher?
http://www.hobbypeople.net/gallery/182374.asp
To me, for hight restrictions the Impulse packs have the skinniest cells available.
Fast5sRevo88
09.26.2008, 05:00 PM
Well 8s would be fine if i had somewhere to put it. This is the tray i will be using and have already ordered....
ID:	5501   Click image for larger version
Fast5sRevo88
09.26.2008, 05:01 PM
That is micke_b's RC8
cheesecake
09.27.2008, 02:58 AM
i put mikes tray in my truggy and now im using the rcpd one it sits way out and it needs a bit of shaving to fit the zippy 5000 its a nice tray though i wish the battery was moved over about 5mm
Fast5sRevo88
10.03.2008, 06:19 PM
Well, i got my buggy, now i just have to wait on everything else.
  • This is what i plan on using;
  • Mike's Motor Mount
  • Flightpower 5s 4350mah Lipo
  • RCPD Ultimate Battery Tray
  • Motor ???
  • Mamba Monster
brushlessboy16
10.03.2008, 06:37 PM
1515-1y :D
10.03.2008, 09:54 PM
Not for 5s. I think a 1512 in the ~1800kv range or a Medusa 36-60-1600 would be good.
big greg
10.03.2008, 10:29 PM
the 2.5d would be sweet on 5s
cheesecake
10.03.2008, 11:07 PM
1512 3d on 5s is a great setup
