a quick mmm question
Semi Pro
Semi Pro's Avatar
a quick mmm question - 10.06.2008, 04:34 PM
so i got my new mmm but all the bullets are touching the heat sink, i called castle and they said its ok
so here is my question, wouldnt that short out the phases? cause cogging and damage to the fets?
10.06.2008, 04:50 PM
They put a non conductive laquer on the bullets and I'm not sure if the HS annodising is conductive but yes there is concern that this can cause a shorting of the phases and hence cogging / failure of the esc.
It may work day1 but the laquer may wear off and create a short...
There was rumour that in V3 the battery side bullets were being removed to create a bit more room for the HS
RBMike
RBMike's Avatar
10.06.2008, 05:13 PM
The coating will wear off, I put heat shrink on them & that is starting to wear thru.
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.06.2008, 05:39 PM
Patrick verified that in one of his posts recently. I was fine with the V1 having all leads direct soldered to the board and wished they had stuck with this. I just like to have a minimum number of connections to loosen.
www.cubicle101.com
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
10.06.2008, 06:37 PM
I like the bullets at least on the motor side. Neu motors aren't ideal in the fact that they don't have solder tabs or regular wires. If they did, a single piece of wire for each phase and a connector at the esc cleans things up the most.
Area 52 Ranch Raceway
T.R.C.R.
10.06.2008, 07:19 PM
the castle mostets have long wires with bullets attached which is why the mmm has the females. With a mmm combo the only connections will be the ones on the mmm.
