MetalMan
MetalMan's Avatar
10.14.2008, 01:39 AM
1512 = 61mm long, 1515 = 68.6mm long, 1521 = 83.8mm long
Neus are a larger diameter, and thus can put out more torque. As a quick guess the Medusas probably put out just a slight bit less than the Neus of similar size.
jacko
Hump-E-Revo
10.14.2008, 02:08 AM
Just finished putting in the order for the 2000kv 70mm motor :) i wonder when they'll send it out. :D
E-Revo Basher:
- MM w/ Fan & CC BEC & 700HO (20/68)
- 2 2s2p SPC 8000mAh
- Maximizer 1/2" Offset w/ Badlands
MR4TC CF/Alum Drifter:
- Novak XBR 8.5 Motor & ESC
- 6-Cell 3300 NiMH
- ABS Tires
portyansky
10.14.2008, 10:35 AM
i knew i should have waited.
10.14.2008, 10:49 AM
Originally Posted by MetalMan View Post
Thanks for posting that! Had no idea they were going to make any 80mm motors... I just preordered a 36-80-1100 V2 for my 9s1p A123 Savage . Came out to $151, let's hope it's worth it!
I do like the look of that motor for 10s lipo... Hmmm, maybe I should get one for the flm savage?
10.14.2008, 10:54 AM
And the power ratings of the 70/80mm motors are more on par with what I would want for larger vehicles (8th scale); 70mm for a buggy and 80mm for a truggy/MT.
drkdgglr
10.14.2008, 11:10 AM
I have read only good things about medusa 60mm motors in revo's and buggy/ truggies.
I know larger can motors will have more torque, but if the 60mm motors seem to be doing well, what would the benefit be of larger cans?
I am currently building a revo which will be running 10s and a 1000-1100kv motor and a muggy on 6s which will be running 1600kv. Both cars will be geared for 40mph. Which size can would suit each car best? I was thinking 36-60-1100 for the revo and 36-70-1600 for the muggy?
MetalMan
MetalMan's Avatar
10.14.2008, 11:20 AM
Larger cans can handle more current without getting as hot due to more surface area to dissipate heat.
If it were my choice to make, I'd go 70mm in both the Revo and Muggy.
portyansky
10.14.2008, 11:22 AM
IMO. It would run cooler and more efficiently b/c it would take less energy/power to get the wheels moving literally. And you should be able to increase your run times since the motor will be more efficient.
I myself will be getting the 60-2000 (for my revo conv.) this Friday, and reading from what others have posted, I shouldnt have any issues. I may get the 70 later on if it proves to be that much of a difference.
10.14.2008, 11:37 AM
Yeah, and it depends on gearing, and what people consider acceptable temperatures. Some people think 150*F+ is ok, but I like temps closer to 130*F max...
10.14.2008, 12:01 PM
So 358*F is too hot? Blast those Hobbycity motors...
Im putting in a pre-order for a 36-70 2200kv, but with Mike since I have a gift voucher to spend.
drkdgglr
10.14.2008, 12:03 PM
Ok, so I can use a 1600kv medusa with 6s and gear for 40mph. Theoretically I can reach these speeds with all three size cans 60,70 and 80mm. I now understand the larger cans will run cooler/ more efficiently. But I don't want the truck to wheelie just by looking at the trigger. Wouldn't that be a problem with a larger can motor?
10.14.2008, 12:22 PM
Hmm, valid arguement. The larger cans will generate more torque and therefore wheelies, but you can do cool things will esc programming to limit punch, and also alter the throttle curve so that the motor spools up a little slower, there by meanig it wont back flip from a standing start. 1600kv & 6s is a nice setup for longer runtimes and cooler temps
jacko
Hump-E-Revo
10.14.2008, 02:22 PM
If it's being run by a MMM ESC, you could always set the punch control or the throttle curve to prevent wheelies from happening and get the benefits of a cooler running motor.
Edit: Woops. Neil just answered it hehe
E-Revo Basher:
- 6-Cell 3300 NiMH
- ABS Tires
drkdgglr
10.14.2008, 02:30 PM
well the revo is going to run 10s, so no mmm in there... but a 12s130amp esc
ffactory666
10.14.2008, 07:16 PM
Wow 80mm versions . I am very happy with my 60 1600kv on 5s in my X2 CRT , would the 80mm 1100kv be the best option for a speed run car as i am probably looking at a 10s set up .
